If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I just bought a miller 330a/bp and have hooked it up to 230v it was set at 460v from the shop I bought it from. Everything works fine and it throws an arc but the gas is on when it should be off and when I step on the pedal it turns off. It is completly backwards. How do I fix this problem?
