i assumed it broke at the usual spot, the spreaders. if yours is broke a the keel that is the most forgiving spot to fix, if bent at cabin, its an iffy fixm cal boats were light and quick, is this mast sufficient for your tig, where are you located,if you are in or near the larger harbours, like marina del ray in la, i would ask around. but i would think that if you got a piece that fits real tight and go from keel to 6 to 8 inchs above the deck, mayby higher if needed, plug weld the **** out of it and at splice seal it up wuth the smallest bead that can be done, sorry for late responce, iv been ill, but have you ever read addalard koles books its a wow read/ take care kevin
