flux core question?
  • flux core question?
    just for the sake of arguement this was brought up today and i wanted to see what everyone else thought........here goes!!!
    if you had 1/16" flux core wire and was doing Vert. and Flat......how wide is max??? I say no wider than you thumb but others disagree.....what do you feel???
    ________
    Honda C200
    Miller Trail Blazer
    Miller Spectrum® 2050
    4 Miller bobcats 225's
    MillerMatic 350 w/ push/pull gun!
    Miller Dialarc 250
    Miller Max Star 150
    2 esab plasmas, Miller stick/tig
    4 lincolns! speedglas 9002v speedglas 9002x with supplied air and filter!
    I guess it depends on how "wide" your thumb is. It could be 5/8" wide, or 1/3/16". Your question stumbles me at the vert. flat part. Running vertical weave as opposed to vertical stringers has differnt parameters. For flat, the same thing, but not the same as vertical.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
      ok so how wide max. would you go for a vertical weave??
      ________
      Vaporizer guide
      Miller Trail Blazer
      Miller Dialarc 250
      Miller Max Star 150
        i use the stuff for most of my weldig and dont go more than 3/8 on width of bead. i run it about 25 volts or higher, and pretty quick wire speed. most of my welding is on structural steel.
          I don't normally use 1/16" often, however with .045" I generally keep a verticle weave limmited to 3/4" for structural welds. If the joint design requires more weld across the face, I use overlapping weaves or just use stringers.
          Jonny
          Dynasty 300DX
          Esab PCM 1000
