how would you figure out how much strenght steel will hold. for example 1" square tubing thats 1/8" thick and 10' long? how would you figure out it's max capacity?
calculations??
Get some and hang weight on it till it fails
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
I don't want to sound too enginerish, but there are probably a thousand correct answers to your question. Is the piece going to be mounted horizontal, vertical? What type/quantity of weld material will be put on it? If horizontal, you could hang several hundred pounds an inch from the end, but put a couple hundred dead center, five foot from any support, and it will most likely bow and maybe fail.
SSSBobcat 250, MM 210, Syncrowave 180, Spectrum 375
1 Thessalonians 4:11-12
Originally posted by hit_em View Posthow would you figure out how much strenght steel will hold. for example 1" square tubing thats 1/8" thick and 10' long? how would you figure out it's max capacity?Tom Veatch
Wichita, KS
like the others said ,the use will greatly efect the amount it will hold as well as where its required to hold it.
the same pice of 1" tube put in any of the situations in the pic atached would hold diferent amounts at any of the points on the pice in question, and thats not even factoring in the welds or the alloy or many other factors. a bock could answer your question if the question was compleat. given the situation you intend to use it in would alow you to then look up what would hold in that situation. i had to do this all the time when building houses with wood but i needed the aplication first then could chose the needed wood dependant apon the size and space aloted. but you need to be spacific about how its used and where and what kind of loads you are alowing for.
after you have all that its just simple calculations.
i'll bet that didnt help a bit did it.thanks for the help
[email protected]
I am not currently building anything like that, I am just wondering if there was any simple mathematical way of calculating the strenght of a piece of metal. I understand once you weld they become one and are much stronger, but can it be figured out using math.
Originally posted by hit_em View PostI am not currently building anything like that, I am just wondering if there was any simple mathematical way of calculating the strenght of a piece of metal. I understand once you weld they become one and are much stronger, but can it be figured out using math.
Its called Engineering. The math is simple, if your decent in Trig, Calc, and Algebra its not an issue. Everything is a function of Geometry and material properties. Welding is no different, its just a function of Geometry and material properties. But this is just for what we call "Strengths and Statics", There is also fatigue and a few other things to worry about.
You dont have to be an "Engineer" to do the math and problem solving, there are lots of good books on the subject. Plus its always nice to have an idea how strong your part is, not just guess
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
