Roll Off Dumpsters
  • Roll Off Dumpsters
    Does anyone do any repairs on 20ft. roll off dumpsters? I wanted to know what I should charge per box, I need to repair 16 of them but the owner wants to keep the repairs $500 and under per box.
    I work for a recycle hauler and we do all our repairs in house so I've seen quick fixes and I've seen ones that have gone down the highway on thier side, I'ld have to say labor and materials would be your best bet, these things take a whippin
    Trailblazer 302G
    MM 210 with spool gun
    Thermal Arc Heffty2 CC/CV suitcase
    Smith torches
    Porter Cable 14" carbide chop saw
    griders and hand tools coming out the WAZOO
    I owe! I owe! so off to work I go!
      I'm going to take a look at them on Friday. I guess that's my best bet.
        For repairs holes, craks etc. what thickness of material do you use for the boxes?
          I would say it depends on what goes in them. If it is general use then I would use 11 gauge (1/8"). That is what the ones I've seen are made from. If it is used for hauling scrap metal or concrete debri then definatly thicker. Probably 3/16" or 1/4" depending on the location in the box. If it's part of the framework (tubing, angle,channel) then match it as best as possible. Make sure you & the customer are on the same page as far as quality of the job. Is it a heat, beat & weld or does he want it cut out & replaced like new?
          MM250
          Trailblazer 250g
          22a feeder
          Lincoln ac/dc 225
          MM200 black face
          Lown 1/8x 36" power roller
          Arco roto-phase model M
          Vectrax 7x12 band saw
          Miller spectrum 875
          30a spoolgun w/wc-24
          RCCS-14
            if they are tub style containers (no ribs) then normally they are normally made out of 3/16", the ones with ribs are normally 11 ga repair, if the ribs are rotted at the bottom we will only replace up as far as needed and cut the inside corner on a 45 to leave it open on the bottom and help drain water out, small holes in the bottom tend to get pluged from either dirt or bigger pieces of rust and then they do nothing, the floor of the open tops are normally 3/16 to 1/4
            Trailblazer 302G
            Smith torches
              It's only going to be a patch up so no debris falls through the cracks. The owner of the boxes wants me to try to do it all for $500 or less a box. He's buying 16 used boxes that are not in good condition eighter way I'll make $. I'm going to try to charge him $500 per box it should all even itself out some boxes might need less repair then others.
                Just a thought....I would make it a point to mix it up on the repairs. Do a couple of easy fixes and then a more involved one. That way, if the owner decided to halt work on them, then you aren't stuck holding the bag on several $750 repairs that you are planning on averaging out. SSS
                Bobcat 250, MM 210, Syncrowave 180, Spectrum 375
                1 Thessalonians 4:11-12
                  Repairs
                  Good money in repairs I did that in 94 for about 4 months and when something better came a long Darmik was gone.
                  Anyway you are going to repair 16 of these things well it's typlicaly 1/8 plate if they are rool offs there should be ribs make sure all the rust is gone before you weld.$500.00 I think should be more like ($1152.00) ok this person wants you to do it for $31.25 per bin hey if your happy with the money they will give you then give her!
                    Darmik,
                    Not $500 for the whole job, (16 boxes) $500 per box thats $8000.
                      Darmik,
                      sorry need help
                        No problem, I'd be crazy to do all of that for $500, I can't even imagine that.
                        Like I said some may need more repairs then others. Thats a fare wage right!!
                          Unless I could inspect all of the boxes to be repaired, I'd only do time & materials. That way you don't shoot yourself in the foot. It also gives the owner some say as to what gets fixed. If you agree to a fixed $500 per container what's to say the guy won't want them all perfect? I don't know how experienced you are but things happen to roll offs that are very time consuming to fix right.
                            If you are just sppulying your self I tinnk you should be fine
                              It's slow season for me so I will try to take whatever I can.
