I have a implement, attached to a Kubota loader with 5 foot arms ( one fixed, the other swivels back and forth) used at a nursery to pick up balled trees. It has become worn where it swivels in the frame and the customer wants it filled in with weld. Any suggestions as to what I should use for rods. Could 6011 be ok to accomplish this task? Thanks
What Rod?
rod
Originally posted by craneops View PostI have a implement, attached to a Kubota loader with 5 foot arms ( one fixed, the other swivels back and forth) used at a nursery to pick up balled trees. It has become worn where it swivels in the frame and the customer wants it filled in with weld. Any suggestions as to what I should use for rods. Could 6011 be ok to accomplish this task? Thanks
i used to use 6013 for building hitches and never had a problem. Its good for old steel and the sorts. I used 7011 also only for welds where gravity wasent concernd, but i've never had any of my welds with a 6013 rod break and i was welding 16,000 lbs hitches and pintle mounts and hitches are taken through some abuse with the rattleing and all , i dunno what the standards are for the rod but they worked for me. I did switch to mig tho , there is so much less work involved.Jorgensen MFG.
Custom trailers:from utility to semi trailers i make em all.
[email protected]
www.ehhitch.com
7018 is all I would use.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by Bmxin^Bjorn View Posti used to use 6013 for building hitches and never had a problem. Its good for old steel and the sorts. I used 7011 also only for welds where gravity wasent concernd, but i've never had any of my welds with a 6013 rod break and i was welding 16,000 lbs hitches and pintle mounts and hitches are taken through some abuse with the rattleing and all , i dunno what the standards are for the rod but they worked for me. I did switch to mig tho , there is so much less work involved.
TJTJ______________________________________
i know what your saying and i understand but it's been working for E&H since 1967 and never has failed , but the point is it does work ,, it's kinda like your not supposto weld 1/2 steel with the mm 135 but if u do it properly it can work... jus my opinion , i've been doing it this way and now have switched to mig but it can work... craneops , my advice to you is do what works best for you. .. it's not like it has to be certified or anything.. i would jus get a few of each rod and see wich one works best.Jorgensen MFG.
[email protected]
www.ehhitch.com
I work for Cat's largest dealership, Finning. I do bore buildups and overlay almost every day, and the best advice I can give you for a build up job is to use 8018 or an 80,000 lb wire. I use Arctec 223XC stick electrodes, however 8018-C3 works just as well. For the very least, use 7018. On smaller bores I can get away with ER70S6 using preheat, but for the larger bores and surfaces stick lasts longer, or fluxcore, and the higher elongation fillermetals tend to be the best.
Photo: This is a pic of a Caterpillar 385 digging bucket. The coupler ear was built up using an 80,000 psi gas shielded fluxcore wire. The weld may not be pretty, but it will be machined off and returned to the new factory state. This type of overlay tends to last longer than the origional metal surface underlying.Jonny
Dynasty 300DX
Esab PCM 1000
Go Away!
Originally posted by MelMcDoogleHere is a good one for work at home programs and whitehat internet marketing tools ; bonus gift free website and money makers at: ChaseTheGlow . Com
