Im building 20ft fixed ladders and using reebar as rungs and have had a couple break,any advice would be helpful.
have Q. about ree-bar
If you are building them where OSHA would be involved remember the rungs have to be 3/4" dia minimum. Are you poking the rungs thru the sidebars? What's breaking on them? One other thing, ladders 20' and higher need saftey cages on them...BobLast edited by aametalmaster; 02-12-2007, 03:32 PM.Bob Wright
Reebar is made from different types of steel, meaning you may have some that has higher carbon and could be hardenable but some may not. so if you have some with high carbon the heat from welding could be making it to hard and brittle. I would recomend using somthing else.
ladders
The ladders are built out of 2.5in-.25 flat bar and .75 reebar with holes punched thru the flat bar. The ladders are 18in wide and I cut the reebar at 18in and weld from the outside. I`m thinking i`ll start cuting a .25in longer so it will stick out a little and get more weld on it and weld on the inside.They are osha invoved, the are for a boiler co.I also build the safety cages and give all a coat of yellow paint.
Originally posted by penetrating welder View PostThe ladders are built out of 2.5in-.25 flat bar and .75 reebar with holes punched thru the flat bar. The ladders are 18in wide and I cut the reebar at 18in and weld from the outside. I`m thinking i`ll start cuting a .25in longer so it will stick out a little and get more weld on it and weld on the inside.They are osha invoved, the are for a boiler co.I also build the safety cages and give all a coat of yellow paint.
Originally posted by penetrating welder View PostThe weld is staying together the reebar pulls out of the flatbar. Any suggestion how to make it stronger.
Hope this helps
BlondieBlondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
Remember............reBar.....does not mean going back to the bar after you have made an a$$ of yourselfNick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
