Why does my wire burn before it comes out the contact tip?
Spool Gun Problem
too high on the voltage ....too low on the wire speed or feeding problems......I'm sure there are more.......more info would help as well.
Good Luck,
MikeGeorge W. Bush was saving your butt whether you liked it or not!
Fear is temporary, regret is forever
HH210 with SG
I assume you are using alum wire? Make sure the hole is the proper size and make sure the wire slides thru the tip hole when the tip is off, if it is tight go to the next size tip. I ran into problems with the proper size tip it seems they were made too small. Try some more wire speed....BobBob Wright
