I purchased a TB 302 last fall. I have always been a stick man, although I decided I need a wire feeder. Ten years ago I had a Snap-On mig; I believe 135 amps, plugged in to a 220 receptacle.
Miller makes the 8VS and the 12VS. Anybody have any suggestions which one I need? Mostly small fabrication work and on occasion, maintenance repair on dozer blades and excavator buckets. I don’t care to get to get to far off the ground, so the weight of the case should not be a concern.
Do I need an argon tank on my rig, or is flux cored wire the way to go. I am still building my trailer, so I need to determine if I need a place for the third tank. At some point aluminum could be something I want to weld. Do I need a separate gun to run aluminum wire?
Thanks in advance, I enjoy all your thoughts, there seems to be a lot of talent that reads this board.
Copperdog's dad
Benton, Pa.
Copperdog's dad
Benton, Pa.
