Pipe Templates
  • Pipe Templates
    WELL THERE IS NOT NO SHADE HERE IN TX. THE LAST COUPLE DAYS. I BEEN MAKING SMALL DIAMETER PIPE TEMPLATES 90/45 DEGREES JUST TO SPEED UP PRODUCTION OUT IN THE FIELD. METAL GEEK HAS A PRETTY GOOD PROGRAM THAT WILL PRINT OUT THE PATTERNS , I TRANSFERED THEM TO PIPE WRAP MATERIAL , WORKS REALLY WELL.
    STILL CONFUSED ON HOW TO FIGURE OUT HOW TO DO A 45 SADDLE PIPE TO PIPE. DAN HOPPER HAS A SITE THAT MAYBE EXPLAINS IN PHILADELPIA LAWYER MATH OR ROCKET SCIENTIST MATH. I GUESS I WILL STICK TO THE CUT TIL IT FITS WAY. I KNOW YOU CAN BUY THESE TEMPLATES AT YOUR LOCAL WELDING SUPPLY,BUT THE WEATHER IS NOT COOPERATING TO DO ANYTHING OUTSIDE , IF ANYONE HAS ANY SUGGESTIONS LET IT RIP!NEVER TO OLD TO LEARN NEW TRICKS OF THE TRADE
    SAN ANTONE I AM IN THE WHARTON AREA.
    /22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
    33x33 enclosed shop when its to cold or windy outside
    miller 210
    miller 875 plasma
    victor oxy/accet
    unihydro 45ton ironworker
    miller 180 tig
    ole lincoln ac/dc buzzbox
    milwaukee power tools
    and everything in between
    2007 trailblazer 302
    Bailiegh 210 miter saw-2008
    Beer Fridge
    6000# cat forklift
    36" port-a-cool fan
    Dake G-75 Belt grinder
    3035 Spoolgun
    Wharton, huh? I know where that is. Have family in the Lake Jackson area.
    On pipe 45's I just use a saw and make a 45° cut on the pipe, then just take a round notch out of the long ends. As long as it does not have to be perfect, that will work fine. Sometimes there is a gap that will take some filling. Precise placement can be difficult with this way, but it can be done.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
      TubeMiter works good too. You can download it from the following link:
      Tube Miter Link
      Hope this helps...
      http://www.jhchoppers.com
        You could buy a Joint jigger, its like a vise that holds the pipe at what angle you want and it has a drill chuck where you attach a hole saw of desired size
        then power it with a hand drill. They work well on thin pipe and on thick pipe if you have a good hole saw. but most hole saws are only good for mild steel or aluminum. dont last long on stainless. If you would like one you can find them alot of places ebay has them usually sell for about 65.00
        sigpichttp://www.sharpsiron.com
          One way is to hold the pipe you are saddling 45 deg. to the base pipe, using a pair of divders and a soap stone attached to it, follow the contour of the base pipe with pointed leg of the divider while marking the saddle pipe with the soap stone leg. this works with same sized pipes or different sized pipes, and different angles. after you make one miter you can transfer that to template materials using center lines.
            Get a pipemaster, works for any angle you want.
            Pipemaster website
            Ed
            Lincoln Tombstone 180 AC
            Hobart Handler 120
            Millermatic 210
            Old Harris O/A setup
            Victor SuperRange II on propane
            Hypertherm Powermax 380
            Ryobi 14" chop saw
            Milwaukee Sawzall
            A bunch of grinders
            A lotta other tools
            Check out my website at: Ed Eldridge's Race Page
              Now thats slick.
                You could use the cut until it fits and then wrap it with paper and cut it out.....then transfer the pattern to some sheet metal etc.......I saw that one on Xtreme 4x4.
                Good Luck,
                Mike
                George W. Bush was saving your butt whether you liked it or not!
                Fear is temporary, regret is forever
                HH210 with SG
                  That Pipemaster is slick, but a 12 inch is 700 clams.....I have used the 2 inchers, they are handy.....too bad you can't just buy a bag of pixie dust or something and go wala....can anyone post pictures of the divider way???? I am still kinda unclear on what was written, I once bought on of those all purpose wraparound gizmos, but lacked the grey matter to figure it out. Thanks, Paul
                  More Spark Today Pleasesigpic
                    Here's a template maker that I built. Print out the 'ruler' to measure your tubing, then enter the tubing sizes. The printed ruler compensates for the scaling of your printer.
                    http://nanosleep.dyndns.org/tubing/
                    Hope this helps
                    -Andy
                    Dynasty200DX w/coolmate1
                    MM210
                    MM Vintage
                    Lincoln AC225
                    Victor O/A, Smith AW1A
                    Cutmaster 81
                    IR 2475N7.5FP
                    Evolution Rage3
                    Jancy USA101
                    9" South Bend
                    AEAD-200LE
                      chop sawing/ notching tubing
                      Try the Link.......lots of good info including what angles to cut depending on tubing size.
                      Pirate 4X4 has lots of good stuff (even if your not a 4X4 guy)
                        Try "The Pipe Fitter's and Pipe Welder's Handbook" by Thomas W. Frankland
                        ISBN0-02-802500-8. It's got tons of great information in a little 3x5 in book.
                        I'd be interested to see that program that will print out templates though especially since I have to do some pipe welding in the near future.
                        Matt Adams A&P, IA
                        Trailblazer 302
                        Dialarc HF
                          Pipe cut outs
                          Try this site plate 'n' sheet developement
                            Another great reference book is The Pipe Fitters Blue Book by W.V. Graves.
                            ISBN 0-9708321-2-5.
                            Use it along with The Pipe Fitter's and Pipe Welder's Handbook that Aircraft Welder recommended and there isn't anything that you cannot do with a piece of pipe. The two books compliment each other very well and are very useful.
                            Flash me! I'm a welder.
                            American by birth, Union by choice! Boilermakers Local 60
                            America is a Union
                              Template online software
                              If you need printable templates go to
                              Harder Woods, tools and software for productive workshops
                              and they will create a printable template
