Well, time to harrass the masses!
Are there any machinists in the house? Here's my dilema- I have three Milwaukee Steel Hawg annular cutters that I've inherited. Got them at an auction and they did not come with an arbor. Milwaukee would love to sell me one for over $200 but I was curious as to whether or not any other arbors will work with them. I know that the ones that Milwaukee sells have a bulb to manually pump fluid onto the work surface. I have no problem keeping the area sufficiently soaked with a spritz bottle if need be.
My next question is where might I get a 4240 model machine? From what I can tell they have been discontinued and I can't seem to even find a used one. The reason I ask is because while trying to add a fourth cutter to the collection I got one off ebay that was not labeled as a quick change version of the bit. Nice, not a problem at the time... But that changed when I found that the new quick change bits are a "tang" drive. The old one, such as I blindly bought, has a channel on the inside for a key to slide into. The outside features a groove running horizontally around it for a collar to grab. Grrr... Any advice??
