need to figure out square inches for a print!! anyone have formula?
help brain fart!
Not sure exactly what you're asking. But for example........if you have a rectangle that is 20" wide and 30" long.........multiply 20"x30" =600 sq inches.
If the rectangle had a bottom, top, and 4 walls making it a box and it was 10" tall, it would be 6000 cubic inches inside. 20" wide x 30" long x 10" tall =6000
ci. Hope this is what you wanted.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
thanks
yea thats it i had a peice of flat 96" long 4" wide and need to know the sq" total! i think i got it!Miller Trail Blazer
Miller Spectrum® 2050
4 Miller bobcats 225's
MillerMatic 350 w/ push/pull gun!
Miller Dialarc 250
Miller Max Star 150
2 esab plasmas, Miller stick/tig
4 lincolns! speedglas 9002v speedglas 9002x with supplied air and filter!
Originally posted by WillietheWelder View Postyea thats it i had a peice of flat 96" long 4" wide and need to know the sq" total! i think i got it!
Your particular case is 4"X 96" = 384 sq in, or alternately 8' X (4/12)' = 32/12 = 2.67 sq ft. If you need to convert sq ft to sq in, simply multiply sq ft by 144 to get sq in or divide sq in by 144 to get sq ft.Tom Veatch
Wichita, KS
Originally posted by TomVeatch View PostMakes no sense, for example to multiply length in feet by width in inches.Triggerman
Ammonia refrigeration tech
Trailblazer 302 (yes, it's new)
Millermatic 180 w/Autoset
CST-250
HF-15 High frequency
XR15 w/Push-Pull Gun
Victor O/A, DeWalt, North mask
"A professional knows what to do. A craftsman knows why."
The formula is simply Area = Length X Width as long as you are working with square, rectangular, or parallegram figures. (Triangular Area is Length X Width / 2.0) Gets a bit more complicated when working with shapes with curved sides. Note that all measurements must be in the same units. Makes no sense, for example to multiply length in feet by width in inches.
Your particular case is 4"X 96" = 384 sq in, or alternately 8' X (4/12)' = 32/12 = 2.67 sq ft. If you need to convert sq ft to sq in, simply multiply sq ft by 144 to get sq in or divide sq in by 144 to get sq ft.Yea, I am 7'2... No, I do not play basketball!
