problems with my 150 stl
  • problems with my 150 stl
    sorry if this is in the wrong section, hopefully the admin can move it if it is.
    anyway i have a maxstar 150 stl welder. iv been using it as a stick welder since i bought it and decided to try tig welding. i bought the regualtor tourch and gas but im having some problems. the welder works fine when im stick weldign but when i select the lift start the ready light wont light up (doesnt blink or anything). the lift start indcator lights up but nothing else. no spark, no arc, nothing. then i switch it back to stick and it works perfectly. am i doing something wrong or is my welder broken?
    Interesting...
    Possibility: There are three settings on the 150STL: Stick, Lift-arc TIG and Ift-arc TIG remote. If you are selecting Tig remote, the welder is probably waiting on the foot pedal to be depressed before being ready. Or, I could be wrong.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
      YES YES YES were getting somewhere. looked up the pin indetification and connected pin 1 to pin 2 and heard the solenoid pop open and i was able to strike an arc! so i looks like for the most part things are working. now i need to figure out how to show the machine that there is no remote connect so it opens the valve byitself. any ideas??
      trigger, man great idea btw!
        If you select lift arc the ready light should come on, if you select lift arc remote remote then the ready light will not come on until you start whichever type of remote you have. At least thats what I remember, I had the torch mounted and the foot remote and never tried to work it any other way. The first models of the STL had only two lights as I recall, one for stick operation and one for tig operation and you needed to do something funny to get lift arc or remote lift arc. I couldn't find any manual for the earily version though, I think it was superceeded by the three light one shortly after they were interduced. I would call Miller's tig shop, they will tell you everything you need to know to get it going right.
        Regards, George
          Sundown: mine only has 2 lights. i bought mine from some guy on craigslist.org. when he sold it to me it only included the stick package so maybe he kept the remote torch and regulator. i think it may still be stuck in remote mode. does anyone know the "funny" thing i have to do to get mine to work without the remote?
          thanks for the help so far!
            If you go here and put in the units serial # that should get you the correct manual.
              Some were sold as stick only and did not include the remote. Matt's advice is right, using the serial number should get you the correct owners manual, if you don't have the serial number then you only get the latest manual.
              Regards, George
                alright got the manual and figured it out. just for future reference what you do is press the selector button and hold it down while turning on the machine. that will enter setup mode. then you can choose the mode you want.
                thanks guys for all the help. i just started tig welding yesterday and im getting the hang of it.
