i recently bought a miller 150 sth.can someone please instruct me on how to set up my regulator.each time i change cylinders the cfh regulator takes alot of tweaking to get set.no leaks are found,today the cfh needle does'nt move at all,and my psi works.please help.
understanding my regulator?
a single stage regulator will change its settings as the presher in the tank changes.
think of it as ajusting a garden hose at your house then going to a frends if the presher is diferent the flow will be diferent, so as the tank emptys the regulator will need to be reajusted, just as it will need to be when put onto a new full tank. the larger the tank the longer it takes to see the change acure, in smaller tanks presher change is faster so more ajusting will be needed.
the only way around this is to get a 2 stage regulator, but they are verry big $'s
nothing wrong with the gage its just the way they are.thanks for the help
[email protected]
I have another question about regulators. I have a Harris that has 2 gages, one for the pressure of the tank and the other for the flow rate of the gas marked in cubic ft. per hour. It has one scale for argon and one for carbon dioxide. My question is does this mean this regulator is Ok for 100% carbon dioxide. I don't do that much continuous mig welding, but it has not frozen up as far as I know. Several years ago, the guy at the Airgas store set up my whole mig outfit so I hope he gave me what I needed.
Thanks
WayneMiller Challenger 172
Hobart AC/DC Stickmate
Older Sears AC Stick machine
Originally posted by wayne50 View Post<snip>My question is does this mean this regulator is Ok for 100% carbon dioxide.<snip>Regards, George
Originally posted by Frank865Why don't you ask the guy that sold it to you?
If you don't trust him, why'd you buy from him?Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
