tandem axle displacement
  • leeschaumberg
    Trailing Axle Placement
    To properly set the axles use the manufactures recomendations. They will say were to put the axles! Fell free to look at any manufacture. Many manufactures exist.
  • SkidSteerSteve
    If it is just going to be a general purpose trailer, then I would stick with the 60/40 rule of thumb. In the case of tandem axles, they would be centered over that point. It's all about weight distribution between the axles and tow vehicle. Too far back and it will over load your truck. Too short and it will be hard to maneuver and will be unstable on the highway. If a trailer sways a lot at speed that is usually a sign that the cg is too far back. SSS
  • 661welder
    Guest started a topic tandem axle displacement
    hello,i am building a tandem axle trailer and i am trying to figure out were to displace the axles on the frame.i am using rubber torsion axles.is there a formula to figure this out or a bias like 60/40 % thanks for any help
