how to bend square tube without bender
  • how to bend square tube without bender
    Hello
    I just found this web site I would like to share, I have not tried them yet, But I will soon.
    http://www.quickfab.ca/
    Miller 301 G w/suitcase feeder
    Millermatic 251
    Miller spoolmatic 30
    Lincoln Ranger8+Diesel, Lincoln SAE 400 amp
    Lincoln SP-125, Lincoln SW 175, Lincoln Pro Cut 55
    Smith O/A, Edwards 75 ton ironworker,
    Grob Brothers Band saw, Hougen magnetic drill
    Thanks for the link.
    Jonny
    Jonny
    Dynasty 300DX
    Esab PCM 1000
      Interesting site.
        Good on
        hey im going to see there prices on shiping but good find keep them coming.
          Really nice of you to post that link. My next trip to home, I will probably have a box from them waiting.
          Again thanks,
          Jerry
            It sounds like the technique that I used to fab up the frame rails on my car.
            you just cut partway through the tube from one end and cut out a triangle with the angle that you want the bend. Then you just bend the tube and weld the butt joint, and you have a bent square tube at the exact angle that you want.
            This technique could be a little tricky to do on slow radius bends though, but I'm sure it could be done.
              Thanks for the link. I am going to see if they have a dealer near me
                Good one, Thanx.
                  Tube Benders
                  I'm into year 4 of my shop build out, and what I hope will be my part-time retirement income.
                  Year 1 - Millermatic 135
                  Year 2 - Miller Dynasty 200DX
                  Year 3 - Miller 625 plasma cutter, TorchMate 4X4 X-Y CNC plasma cutting
                  table
                  Year 4 - pipe, metal, and scroll working tools
                  (http://www.shopoutfitters.com/)
                  Year 5 - Lathe and/or lathe/drill/mill
                  My point being - yes you can buy pre-bent metal at a premium, or you can buy a tool to do it - look at long term Return On Investment (ROI).
                  Steve
                    Kerf bending? Common woodworking technique to get slow bends. Would leave a poorly prepared joint for welding, 'though, and probably a slightly faceted bend.
                    Tom Veatch
                    Wichita, KS
                      good link
                      thank for the info
                      miller bobcat 250
                      wc 115a
                      spoolmatic 30a
                      centery 250 mic
                      2 lincoln 225 stick
                      a 1954 hobart portable welder w/ willies jeep engine
                        more info
                        I bought a bunch of 1” 90 deg (I have an inventory of 1 “sq. tubing won’t go to waste) Arranging them (see pic) you can make things you can’t with a bender. I’m not connected to this company, just sharing info with the brethren.
                        Millermatic 251
                          they could defenetly speed things up for many aplications if you dont mind MIGing them up and dont want pointed corners. cool idea though.
                          thanks for the help
                          feel free to shoot me an e-mail direct i have time to chat. james@newyorkmetalart.com
                            I would love to see some pics of things you make with the elbows.
                            Thanks
                              Used a 4" pipe to bend 1/2 stuff and then moved to a 25lb lifting weight to bend the 3/4 stuff. Worked great, no heat either just elbow grease.
