Hello, I was wondering if someone could help me figure out the problem I'm having with my TIG. I have a Miller Syncrowave 250 at home, but I also am using one at school, and I am trying to weld Aluminum. At school, when I weld aluminum for practice it comes out really nice, but when I do it at home with my welder there is some brown crap that ends up in the end of every weld I make. Sometimes the brown crap floats in my weld puddle, where it is carried in the puddle until the weld is completed. I told my welding teacher about the problem I'm having, so just to be sure I didn't have contaminated filler rod at home, he gave me some filler rod that we used in class, as well as a few pieces of the Aluminum used in class, and even a small stainless brush in case mine was not stainless. Here are some other facts:
-On both welders I am using the same 2% Thoriated Tungsten
-Both welders use Argon
-Both welders are on the same settings, although I might have the gas pressure setting wrong, I have ranged it between 20 and 35 psi though
-On my torch I put a brand new ceramic and tungsten. I also prepared it with a grinder that hasn't touched steel and I balled the tungsten properly
-My torch is air cooled and the school's torch is water cooled, but I have welded with my torch without this problem before, it just started happening recently.
This problem is driving me nuts, any input would be truly appreciated.
Thanks!
-Gary, GMarchand
Thanks!
-Gary, GMarchand
