Adding Third Arm to Bird Feeder
  • Adding Third Arm to Bird Feeder
    My wife decided that she needed one more feeder, so I converted a two-arm bird feeder pole to a three-arm pole. The larger birds and the Oriels are hesitant to go to the feeder closer to the house. They are more comfortable using a feeder further from the house. Here is a picture of the original two-arm pole:
    1. Double arm feeder
    Click image for larger version  Name:	1. Double arm feeder.jpg Views:	0 Size:	60.3 KB ID:	623467
    I set the Fireball adjustable square to 120⁰, so that the arms would be equally spaced. The bird feeder pole is only ½” so it is kind of wimpy. Keeping the feeders equally spaced and close to the pole minimized the unbalance force on the pole.
    2. 120⁰ Fireball square
    Click image for larger version  Name:	2. 120⁰ Fireball square.jpg Views:	0 Size:	156.0 KB ID:	623468
    I MIG welded the ½” bars using the 3/8” default setting on the welder.
    3. Two arms welded together
    Click image for larger version  Name:	3. Two arms welded together.jpg Views:	0 Size:	105.1 KB ID:	623469
    4. Third arm welded
    Click image for larger version  Name:	4. Third arm welded.jpg Views:	0 Size:	177.8 KB ID:	623470
    5. All done
    Click image for larger version  Name:	5. All done.jpg Views:	0 Size:	129.2 KB ID:	623471
    -Don
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Everlast PowerTIG 400 EXT
    What, no CAD drawings on this? Inconceivable!
      Ryan,
      Sorry, I’ll get right on it.
      -Don
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DoAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
