Riser for Bicycle Aero Bars 2
  • Riser for Bicycle Aero Bars 2
    Back in April I designed and built a riser for my aerobars to create a more comfortable position for my forearms while using the aero bars on my mountain bicycle. Here is a link to the post.
    https://weldingweb.com/vbb/threads/7...ycle-Aero-Bars
    The following is a picture of the aero bars with the riser as well as a close-up picture.
    1. Original aero bar close up
Name:	1. Original aero bar close up.jpg
    2. Original aero bar
Name:	2. Original aero bar.jpg
    One comment from Rexcormack on the welding web forum got me thinking:
    “Re: Riser for Bicycle Aero Bars
    Nice job but keep an eye on those fasteners at the bottom.
    That will be your weak link because of the leverage those risers will have!”
    As a result of the comment, I decided to add a diagonal brace to each riser to minimize the stress on the two M6 screws. The design is shown below.
    3. New diagonal brace
Name:	3. New diagonal brace.jpg
    The first step was coping the diagonal brace tube.
    4. Setup for coping tube
Name:	4. Setup for coping tube.jpg
    5. Coping setup close up
Name:	5. Coping setup close up.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Everlast PowerTIG 400 EXT
    And here are the tubes all done.
    6. Tubes all done
Name:	6. Tubes all done.jpg
    To make the feet I cut out the drawing of the feet and glued the drawing to a piece of aluminum.
    7. Cutting out feet
Name:	7. Cutting out feet.jpg
    The cost of the original aero bar assembly was $21, so I purchased a second assembly just for the clamps. I can’t manually machine a clamp for $10.50. I removed the excess material from the clamps.
    8. Cut down clamp
Name:	8. Cut down clamp.jpg
    Notice the cross hatched pattern indicating that the head of my Bridgeport is properly trammed in.
    9. Cross hatched finish
Name:	9. Cross hatched finish.jpg
    Here are a couple of close-up pictures of the welds.
    10. Weld 1
Name:	10. Weld 1.jpg
ID:	623494 Click image for larger version
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      11. Weld 2
Name:	11. Weld 2.jpg
      12. Weld 3
Name:	12. Weld 3.jpg
      And here are two pictures of the aerobars with the diagonal brace in place.
      13. Close up of diagonal brace
Name:	13. Close up of diagonal brace.jpg
      14. All done
Name:	14. All done.jpg
      One thing that I like about this forum is comments tha t if taken improve the design or at least the next design.
      -Don
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DoAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
