Anne’s Bird Feeder Pole
  • Anne’s Bird Feeder Pole
    Recently I remodeled the family room. As a part of the renovation, we replaced the windows. The swing arm that supported two of the bird feeders was attached to the frame of the old windows. We didn’t want to attach the swing arm to the new windows, so I designed a sturdy 1-1/4” black pipe pole to support it. While I was at it, I added bosses for a second swing arm to the other side of the pole. It turns out the ¾” EMT conduit is the same size and wall thickness as the original swing arm, so I will use ¾” EMT to make the second swing arm. My wife really enjoys the birds, so I made this new pole for her, so she can continue to feed her birds.
    1. Pole asm
Name:	1. Pole asm.jpg
    2. SolidWorks drawing
Name:	2. SolidWorks drawing.jpg
    3. Point machined
Name:	3. Point machined.jpg
    4. Point in place for welding
Name:	4. Point in place for welding.jpg
    5. First pass
Name:	5. First pass.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Everlast PowerTIG 400 EXT
    6. Cover pass
Name:	6. Cover pass.jpg
    I chose to use Dual Shield Flux Core wire (FCAW-G) to attach the cross plate to the tube. The plate is 3/8” thick and I was concerned with penetration if I used short circuit MIG. Here are the parameters that I used:
    Process: Dual Shield flux core (FCAW-G)
    Welder: Lincoln 210 MP
    Gas: 75% Ar 25% CO2
    Wire: .035” Lincoln 71M (E71-T1M)
    WFS: 360 IPM
    Voltage: 24.0 volts
    Shielding Gas: 30 CFH
    CTWD: 3/4” – 1”
    These settings are close to the settings on the Lincoln cut sheet for this wire:
    350 IPM WFS @ 23-26 volts
    or
    400 IPM WFS @ 24-27 volts
    7. Cross plate welded
Name:	7. Cross plate welded.jpg
    8. Boss Welded
Name:	8. Boss Welded.jpg
    9. Pole painted
Name:	9. Pole painted.jpg
    10. Boss painted
Name:	10. Boss painted.jpg
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      11. Cross plate painted
Name:	11. Cross plate painted.jpg
      12. Point painted
Name:	12. Point painted.jpg
      I still have to install the pole and make the 2nd swing arm. Attached is a link to a one minute 22 second video showing the machining steps that I used to make all of the parts. It turns out that there are a lot of steps.
      https://drive.google.com/file/d/1OaV...w?usp=drivesdk
      -Don
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DoAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
