It is common for the 4 vertical posts to be made of heavy flat bar. It is also common for the sliding horizontal table to be made of 2 pieces of channel back to back, connected at the ends.
I'm considering buying a used one, only I'm scared of getting a wreck with the plumbing destroyed. I have to find a type that in the event of an overhaul I find the worn parts to replace.
