Welding Spherical Rod End on Shaft
  • Welding Spherical Rod End on Shaft
    My customer is in the process of restoring a vintage Karmann Ghia. He required a push rod for the master cylinder. He couldn’t purchase the correct part, so he bought one that was too long. He cut off the end of the shaft to make it the correct length and requested that I weld a ball back onto the end of the shaft. The top view in the following shows a Xerox of the correct shaft. The bottom view shows the shaft that was too long, which had been shortened. He wanted me to weld a ball on the end of the shaft that looks like the Xerox picture.
    1. Shaft that requires a spherical rod end
Name:	1. Shaft that requires a spherical rod end.jpg
    2. Me welding a ball on the end of the shaft
Name:	2. Me welding a ball on the end of the shaft.jpg
    3. Ball as welded
Name:	3. Ball as welded.jpg
    4. Grinding a rod end
Name:	4. Grinding a rod end.jpg
    5. Rod end all done
Name:	5. Rod end all done.jpg
    -Don
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Would it have been easier if he cut a chunk out of the middle of the one that was too long and then had it welded back together instead of welding just a ball back on the end? At first I thought so, and now I don't know if it would make much difference. You'd have a much better idea.
      Might have been just as easy to machine a new one from bar stock, eh Don? You would’ve had to grind the living daylights out of some HSS too!
        I’m not sure exact what the customer did, because there is evidence of welding in the middle of the shaft. My repair was actually pretty easy, I just built up the end of the shaft with weld. I used enough heat to keep the weld bead spherical in shape.
        -Don
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DoAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          I could have machined it from a solid bar. I do have carbide radius cutter bits for the lathe.
          -Don
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DoAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
