Frame for Coolant Mist Tank on DoAll Saw
  • Frame for Coolant Mist Tank on DoAll Saw
    For this project I am fabricating a frame to hold the coolant mist tank on the DoAll vertical saw. The best place for the tank is above anything that is being cut, so that the lines and tank don’t interfere with the stock that is being fed through the saw. The previous owner of the saw installed a piece of flat bar stock to mount a light. I decided to add the frame to the top of the existing flat bar stock. The red arrow points to the bar stock in the following picture. The light itself is in the back of the saw so it isn’t visible in this picture.
    1. DoAll saw
Name:	1. DoAll saw.jpg
    The first step was to weld two long pieces of angle iron to the top of the bar stock.
    2. Long pieces welded
Name:	2. Long pieces welded.jpg
    3. Close up of weld
Name:	3. Close up of weld.jpg
    The next step is to weld short pieces of angle iron to the ends of the long angle iron pieces to complete the frame. I welded the frame from the outside and left a gap between the pieces to get good penetration without having weld on the inside of the frame, which would interfere with the tank.
    4. End piece 1
Name:	4. End piece 1.jpg
    5. End piece 2
Name:	5. End Piece 2.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    After welding up the end pieces, I ground the welds flush with the surface of the frame and painted it.
    6. Top of frame
Name:	6. Top of frame.jpg
    7. Bottom of frame
Name:	7. Bottom of frame.jpg
    As you can see, grinding the welds flush made them disappear.
    8. Close up of bottom of frame
Name:	8. Close up of bottom of frame.jpg
    Painting the frame made it appear to be part of the saw.
    9. Frame attached to saw
Name:	9. Frame attached to saw.jpg
    And the last picture shows the coolant tank mounted on top of the new frame on the DoAll saw. As you can see, the bottom of the frame provided a nice surface to mount the magnetic base of the nozzle holder.
    10. Coolant tank mounted
Name:	10. Coolant tank mounted.jpg
    -Don
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Good job, Don. How much air do you have to put into that thing?
        The mister system doesn’t require too much air. I just have a small air compressor. In use the mister makes a hissing sound, like a leak on an airline. You mix a few ounces of concentrated coolant to a gallon of water, so the mix is mostly water. In addition to acting as a cutting fluid, the other advantage of a mist system is removing the heat from the cutting area, which really extends the life of cutting tools and saw blades.
        -Don
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DoAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          I was looking to put a mister on the Bridgeport and I still might, but I wasn’t sure if I needed to regulate the air pressure down or if I could just plug it into the system that’s charged at 125psi.
            I just plug mine into my shop air ~90 psi. The mister has a needle valve to cut down the air flow.
            -Don
            Lincoln LE 31 MP
            Lincoln 210 MP
            16" DoAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              Cool man! That makes it easy. The Bridgeport is right by the air tank, which happens to have several unused ports, so I can tap a port and be off! Plus I think with the right fluid if will helps keep the table in better shape. In this humidity, everything rusts so fast. Just surface rust, but still irritating.
