So i recently posted my fabrication business online and started to get alot of custom order for catalytic converter shields for peoples cars and trucks.. which is great, most of the vehicles ive already made templates for have existing holes in the frames that go thru so i can mount using 3" and 4" security bolts. BUT i ran into an installation this weekend that the hole did not go all the way thru and was at a lost for how to secure it with only a partial hole..
I thought about the threaded insert rivets, but i cant find anything large enough, then i thought about jack nuts, but again, couldnt find anything large enough. The holes on this vehicle are between 13/16 and 7/8 round, i had ordered some "L" hook bolts, but those didnt work out..
They are coming back next weekend and i need to figure something out that would work and be secure to hold this in shield in place.
Do they make any "toggle" like nuts that would be worth trying.. im not looking to make it cheesy, i want to do it right
I was able to cut a larger washer to the size of the hole and it fit in perfectly, i could weld a nut to that so that i can secure it. BUT not sure how to keep the nut/washer from moving while tightening the bolt.
The other idea i had was to weld the washer to the "L" bolt up high enough on the neck of the bolt so that i can slide the bolt up into the hole and once tight the pressure would keep things in place..
Just kinda at a loss on what i can make or what is available to use these existing holes that DO NOT go all the way thru the frame.
Keeping in mind that im not looking to make any modifications to the frame in anyway..
