John Deere excavator upper track roller
  • John Deere excavator upper track roller
    Bolts for upper roller all broke off. Kept using it and now the mounting block is worn into the first pair of bolts. Owner wants it welded on as it is now catching on the track. Hooked chain from outer side of track to boom lifted up for clearance, then hooked come a long to inner side to level it out. I was able to slide roller in and weld it on. Grooved it out ahead of time so had a nice vee on each side.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    Tacked it on and a few passes around with 7018. Good to go.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Miller spectrum 875
    RCCS-14
      Hopefully it lasts a long time and I'll be retired although job went better than ecpected. Wouldn't be to much to gouge it off and weld in a new one.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Miller spectrum 875
      RCCS-14
        Thats a good fix. No better way to do it there and then than that. The bad news, its broke,,, the good is we can fix it shortly.
          How in the world did the operator not know he lost an idler like that?
          Good on site repair.
