A Davit is a small crane onboard a ship, especially one of a pair that are used for suspending or lowering a lifeboat. My friend and customer Ray has designed a Davit system to lift up his dinghy onto the swim platform of his boat. This post describes the brackets that will attach to the bottom of the inserts, which were previously glued into the swim platform. The purpose of the bracket assembly is to connect the bottom of the inserts to the Aluminum fabrication that supports and lifts the swim platform to take some of the load off the glue on the inserts.
The first picture shows a Davit from another boat, to give you an idea of the typical design of the Davit. The support brackets described in this post would be located below the swim platform.
1. Davit
The following picture shows the support bracket assembly for one side of the Davit. The two inserts on the top are 2” in diameter have a M10 x 1.5 thread and were previously glued into 2” holes that were drilled in the swim platform of the boat. (See Davit – Part 1 for information regarding gluing of the inserts).
2. Davit support bracket asm
The pair of support brackets that I machined from angle Aluminum are shown below.
3. Support brackets
I wanted to clamp the angle aluminum to a piece of plywood resting on the table of the milling machine. The plywood allowed me to drill and mill the angle Aluminum without cutting into the table of my milling machine. This configuration forced me to use an extra long center drill to reach past the leg of the angle Aluminum.
4. Extra-long center drill
5. Plywood under angle
1. Davit
3. Support brackets
