A Davit is a small crane onboard a ship, especially one of a pair that are used for suspending or lowering a lifeboat. My friend and customer Ray has designed a Davit system to lift up his dinghy onto the swim platform of his boat. This post describes the inserts that I made, as well as the drilling and gluing fixture which were used to glue the inserts to the swim platform. The inserts will eventually support the davit. The first three pictures show a pair of Davits from another boat, to give you an idea of the typical design of the Davits.
1. Dinghy on davits 1
2. Davits 2
3. Davits 3
The next picture shows one of the 2” OD Aluminum inserts. The inserts were tapped for a M10 x 1.5 Helicoil. Notice the slight chatter on the grooves in the following picture. I machined this insert using a long piece of stock with steady rest, to minimize the stock wastage.
4. Insert
I left the chatter because it won’t hurt the function of the insert, but I did eliminate the chatter as shown in the following picture by using a more rigid setup.
5. Cutting groove
2. Davits 2
3. Davits 3
4. Insert
5. Cutting groove
