2 foot excavator bucket crack
  • 2 foot excavator bucket crack
    Fixed this years ago. Broke again right next to old repair but operator didn't see it so much bigger this time. This machine leads a hard life picking and digging rocks. Lots of prying and lifting rocks with the thumb that are bigger than should be. Set it up on a rock to get it at comfortable working height, put down pressure to close up crack. Welded inside 3 passes with 7018 then air arced outside till I hit inside weld. Ground clean then multiple passes with Hobart 21b flux core grinding clean in between each pass.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    In the middle of welding up the outside lit up my pants. Annoying when this happens but part of the job.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Miller spectrum 875
    RCCS-14
      I was going to be upset if you didn’t post a picture of your britches!
      They building stone retaining walls with that little bucket?
        Caught myself on fire today too, too lazy to get a good glove on and get in a good spot.
          my uncle patched up the buckets of the mechanical shovels, as reinforcement he put the thick iron rods for the reinforced concrete or the leaf spring sheets of the truck suspensions. depends on the size of the bucket.
