Skeg Repair
  • Skeg Repair
    My friend and customer Steve has owned this 27’ boat for 25 years. Counting the boat that he had before this one, he has owned power boats for 35 years. Steve’s strategy is to leave the boat in storage and trailer it to the lake every time that he uses it. For the first time in 35 years, he forgot to raise the lower unit of the inboard/outboard drive when he pulled the boat out of water. As a result, he wore about ¾” from the bottom of the skeg. My task was to replace the worn off piece of the skeg. Steve felt that the bottom of the skeg helps to protect the two counter rotating stainless-steel propellers, which cost ~ $2,500. If the skeg hits something on the bottom it will likely cause the lower unit of the inboard/outboard drive to rise and avoid damaging the propellers. (At least that is the theory.)
    1. Steve’s 27' boat-1
Name:	1. Steve's 27' boat-1.jpg
    2. Steve's 27' boat-2
Name:	2. Steve's 27' boat-2.jpg
    3. Worn down skeg
Name:	3. Worn down skeg.jpg
    I know that it is low tech, but I just used a cardstock pattern to define the shape of the replacement piece for the skeg.
    4. Cardstock pattern
Name:	4. Cardstock pattern.jpg
    Ryan Jones from the Miller Welds forum queued me in regarding the availability of replacement skegs. It turns out the skegs are airfoil in shape with the center being about twice as thick and the leading and trailing ends. In our case the center was .220” and the ends were .100”. I compromised by using 3/16” stock. If you want to be geometrically pure, you would have to cut the bottom off of the replacement skeg tip. Another option is to use 1/4” stock and do a lot of grinding if you want to blend it to the existing skeg.
    5. Replacement skeg tip
Name:	5. Replacement skeg tip.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    6. Cutting replacement piece
Name:	6. Cutting replacement piece.jpg
    I like to use a copper backup plate to protect the back of the weld from oxidation during welding.
    7. Copper backup plate
Name:	7. Copper backup plate.jpg
    I used garbage cans and a small shade to protect me from wind. The part that I was welding was far enough from the gear box that I didn’t worry about burning up the grease. I also took my time welding it, so it would cool off between welds.
    8. Me TIG welding skeg
Name:	8. Me TIG welding skeg.jpg
    9. Close up of me welding
Name:	9. Close up of me welding.jpg
    10. Skeg welded
Name:	10. Skeg welded.jpg
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      When you grind aluminum make sure that you use a wheel designed for Aluminum, like the one shown below, otherwise the wheel will load up.
      11. Aluminum grinding wheel
Name:	11. Aluminum grinding wheel.jpg
      I like to back gouge to ensure that I remove all of the oxidation from the back of the weld.
      12. Back gouging skeg
Name:	12. Back gouging skeg.jpg
      In the evening here in Michigan it is currently in the low 50’s, so I used my shop lights to help the paint to dry.
      13. Using 2x 500-watt lights to dry paint
Name:	13. Using 2x 500-watt lights to dry paint.jpg
      14. All done and painted-1
Name:	14. All done and painted-1.jpg
      15. All done and painted-2
Name:	15. All done and painted-2.jpg
      -Don
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DoAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Your customer is lucky he didn’t grind off part of his prop too!
        CAD to me means cardboard aided drafting, so your card stock is as high tech as my shop gets!
        Good repair.
          The props are in excellent shape considering that they are the original ones. The only problem he ever had was that the seal wore a groove in the journal of the prop and leaked. He had the journal spray ceramic coated and ground and the props have worked ever since.
          LOL
          Good repair.
          Thanks
          ​​​​​​-Don
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DoAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
