I’m making a 2 into one manifold for a friend. The u-bend is slightly too wide, so that the ends do not mate up exactly to the intake ports. I don’t think I can bend the u bend a little more to get the right length or I suppose I can some out of the middle of the bend and weld it back up. It’s aluminum and I’d like for there not to be any obstruction from the penetration. Any ideas on how to fix this?
Intake manifold
You’ll have to do some pie cuts, you can get any angle or lineup you want using that method. If you’ve never done it, I’d suggest you practice your cuts first. Use either 9 or 18 degree cuts. I prefer 9 degrees, but you get more lateral shift out of 18 degree cuts, but I doubt you’ll need much. It’s time consuming and can be confusing if you’ve never done it. I use a wood miter chop saw to cut aluminum and have been doing that with great success for years. I’ve done a fair amount of motorcycle intake and exhaust like this. As long as your cuts are all the same, you’ll be able to snake it around to get the exact lineup you need.
