My friend and customer Chuck wanted a sturdy pole to hold a bird feeder bracket. The problem is that for some reason the arm of the bracket was three feet long, so it would apply a moment load to the pole. The other problem is that he wanted to mount the bracket 6-1/2 feet high so that people could walk under the bracket without hitting it. The first step was to make a SolidWorks model of the pole.
1. Concept Model
I find that my mister is great for keeping the part cool while taking heavy cuts.
2. Mister to keep part cool
I needed to cut a slot in the pole. To fit the pole in the room where my milling machine is located I had to rotate the waist of the Bridgeport and extend the ram as shown below.
3. Offset waist of Bridgeport
4. Slot milled
I used my lathe to chamfer the end of the pipe. I know that the chamfer doesn’t require the accuracy provided by the lathe, but I have a lathe and this is a very fast operation.
5. End chamfered
1. Concept Model
4. Slot milled
5. End chamfered
