Receiver for Rear of Trailer
  • Receiver for Rear of Trailer
    My friend Rick wanted me to fabricate a receiver that would mount to the cargo carrier on the rear of the trailer that would allow him to install a bicycle rack to the receiver, when desired. With this design the bicycle rack would be easy to remove from the cargo carrier when it wasn’t required. Rick originally wanted to use a piece of angle iron that he had for the cross brace, but I talked him into using a piece of square tubing, for improved torsional rigidity. I didn’t want the bicycles to bounce around too much -- particularly the heavier electric bicycle.
    1. Original Plan
Name:	1. Original Plan.jpg
    Rick wanted the bottom of of the receiver to be flush with the deck to we installed the receiver tube offset on the top as shown below.
    2. Offset receiver
Name:	2. Offset receiver.jpg
    I welded a tab to the top of the cross tube to close off the hole caused by the offset receiver tube.
    3. Offset tab
Name:	3. Offset tab.jpg
    Notice the Fireball square that I used to square up the receiver to the cross tube.
    4. Tack welding
Name:	4. Tack welding.jpg
    5. Welding it out
Name:	5. Welding it out.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    6. Me welding the end cap
Name:	6. Me welding the end cap.jpg
    7. End cap welded
Name:	7. End cap welded.jpg
    8. Bottom of receiver welded
Name:	8. Bottom of receiver welded.jpg
    9.All welded top view
Name:	9.All welded top view.jpg
    10. Welded bottom view
Name:	10. Welded bottom view.jpg
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      11. Painted
Name:	11. Painted.jpg
      12. Mounted on cargo carrier
Name:	12. Mounted on cargo carrier.jpg
      -Don
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DoAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Good and proper, Don.
          Does he have a swim platform off the back of his camper there?
            It looks like a swim platform, doesn’t it?
            Don
            Lincoln LE 31 MP
            Lincoln 210 MP
            16" DoAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              Nice job, I like it!
              A FEW OF MY TOYS !!!
              MX Linux
              LinuxMint
              Miller Roughneck 2E
              Lincoln Weldpak 100
              Gianttech Arc 200
                Thanks, here Is a picture of the bicycles mounted on the rack that Rick just sent to me.
                -Don
                Lincoln LE 31 MP
                Lincoln 210 MP
                16" DoAll Saw
                15" Drill Press
                20 Ton Arbor Press
                Bridgeport
