Steel Rack Extension
  • Steel Rack Extension
    I have a couple of heavy-duty racks that I use to store steel. One of the racks sticks through a hole in the wall which limits the maximum height of the rack. I decided to cut off the unusable top of the rack and use it to extend the height of a second rack, located in my addition, where there is more head room.
    1. Old rack
Name:	1. Old rack.jpg
    After cutting off the four corner columns, I ground off the cross brace. The original cross brace was 18 inches long and the new one needed to be 24” long. Also, the new brace needed to have a higher section because I wanted to rest some metal directly on the cross brace.
    2. Grinding off cross brace
Name:	2. Grinding off cross brace.jpg
    I selected a 1/16” wall 1-1/2” square tube for the new cross brace. I used my Fireball angles and magnetic blocks to fixture the frame in place. I find the Fireball tools to be very useful.
    3. Fixturing with Fireball Tools
Name:	3. Fixturing with Fireball Tools.jpg
    The next step was to tack weld the cross brace in place. I tack welded all four sides of each tube before I welded it out. I used my Lincoln LE31 MP welder which is 140 amp 120 volt multi-process welder. I used .030” wire, which was in the welder, but I should have switched to .025” wire, because the thickness of the columns was only about .035” (Not including the paint).
    4. Tack welds
Name:	4. Tack welds.jpg
    Next, I welded it the frame. I positioned the frame so that the heavier 1/16” wall tube was on the top, to help prevent burning through the thinner metal of the columns on the bottom.
    5. Weld-1
Name:	5. Weld-1.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    6. Weld-2
Name:	6. Weld-2.jpg
    Here are two pictures of the extension frames on top of the existing steel rack.
    7. Frame-1
Name:	7. Frame-1.jpg
    8. Frame-2
Name:	8. Frame-2.jpg
    I blind riveted tabs on the end of the extensions to align the extensions with the existing columns of the steel rack. I was planning on welding the extensions, but it was so rigid that I didn’t bother welding them.
    9. Blind rivet splice
Name:	9. Blind rivet splice.jpg
    And here it is all done.
    10. All done
Name:	10. All done.jpg
    -Don
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      I like those big squares, Don. When you’re done, you can send them to me.
        I really like all of the Fireball products.
        I would like to purchase the next larger size square as well.
        it will have to wait, because I just bought a precision 8” Chuck for my lathe.
        -Don
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
Name:	steel rack large.JPG
ID:	616466 Click image for larger version
ID:	616467 Click image for larger version
ID:	616468 Click image for larger version
Name:	steel trays.JPG
ID:	616469 Click image for larger version
Name:	steel coupons.JPG
            Don, if you look can see a similar deal on top of my big one. It isnt as custom as yours, was a whiz deal.
              I love your metal collection. I am jealous.
              -Don
              Miller Thunderbolt
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                Don. I collect it and process so to speak
                trim it to store. I rarely buy steel and haven't for long time. I find so much so close, even holes in it.
                we were installing/working in a roadside ditch the other day and find a piece of 1/4 2 1/2 x 2 1/2 angle near new about 5 ft long must forgot to finish weld in on a county truck.
