To bolt or to weld thats the ?
  • To bolt or to weld thats the ?
    I am building a Handle 4 my Lincoln 3200 HD cart I don`t know if I should bolt it or weld it to the cart ???? It is pretty thin metal the cart is but I think it wold be stronger and easier if I welded it
    Inferno Forge
    Chris
    i figure, if you can think of a reason the handle might ever be in the way (like rolling it under a table) bolt it. if not, weld that sucker.
      Thanks for the adice I am gonna" Weld that Sucker"
      : Thanks ,Wireburner (Chris)
      Inferno Forge
      Chris
        what kind of ???? is that? did you buy a wrench or a welder.
        thanks for the help
          Use Bolts.
          R W
            Use Bolts.
            R W
            he must not have a welder.
            thanks for the help
              Think of welding it as a hybrid of the two. Use the welder first, then the blue-tipped wrench if you ever need to loosen it. SSS
              Bobcat 250, MM 210, Syncrowave 180, Spectrum 375
              1 Thessalonians 4:11-12
