Rod oven carrier modification.
  • Rod oven carrier modification.
    In the past I would purchase low hydrogen rods such as 7018 in ten pound hermitically sealed containers, as shown below.
    1. Ten pounds of rods
Name:	1. Ten pounds of rods.jpg
    The problem is that once the container is opened you need to store it in an oven at 250° F, to prevent the rods from absorbing moisture, otherwise the rods couldn’t be used for any critical application. I do mostly TIG, MIG and Flux Core welding, so I don’t use too many rods in my shop. I have never invested in a shop size rod oven and even if I had one, I would be hesitant to pay for the electricity to keep it powered for months without using any rods. As a result, I decided to purchase my 7018 rods in one pound hermitically sealed containers. I stock 3/32”, 1/8” and 5/32” sizes. The rods in these smaller containers are double the cost of rods in the 10 lb containers, but the waste would be much less, especially considering that I only use a few rods for each job.
    2. One pound rod containers
Name:	2. One pound rod containers.jpg
    I have outside job planned, to weld a bracket for a boat hoist, which is located on Lake Saint Claire. I am waiting for a day that isn’t raining, has low wind that my friend and customer, Mark is available. I was rusty on out of position stick welding, so I have mocked up and practiced welding the required joints. Between practice sessions I have stored the low hydrogen rods in my portable rod oven.
    3. Rod oven closed
Name:	3. Rod oven closed.jpg
    4. Rod oven open
Name:	4. Rod oven open.jpg
    Below is a picture of the rod holder that goes into the portable rod oven. I added the ring in the middle to keep the rods together.
    5. Rod holder
Name:	5. Rod holder.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    To make the ring the first step was to bend a bar into a ring.
    6. Bending bar
Name:	6. Bending bar.jpg
    7. Ready for welding
Name:	7. Ready for welding.jpg
    8. Ring welded
Name:	8. Ring welded.jpg
    9. Rod holder complete
Name:	9. Rod holder complete.jpg
    I keep my conventional rods (all rods except low hydrogen) in a bun warmer to keep them dry.
    10. Bun warmer closed
Name:	10. Bun warmer closed.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      11. Bun warmer open
Name:	11. Bun warmer open.jpg
      Here in Michigan, it has been raining almost every day. I left an open package of 6011 rods out for one week, between practice sessions. The rods absorbed moisture and sputtered when I tried to use them. The package says to heat the rods from 70 to 80° C (158 to 176° F) for 30 to 60 minutes before using. My portable rod oven was set to 250° F, because I was storing 7018 rods in it. I figured that the rods contain Cellulose, so the higher temperature should be ok, because paper burns at ~ 480° F. It turns out I was wrong and the rods started to smoke. The baked rods changed to a darker color as shown below. I used the baked rods to complete my practice and they seemed to weld ok. In the future I will re-heat 6010/6011 rods to 160° F as directed.
      12. New and baked rods
Name:	12. New and baked rods.jpg
      Hopefully I will be able to weld the boat hoist this next weekend.
      -Don
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        I just bought, haven’t taken delivery of just yet, a large rod oven. I was considering putting it on a timer so it doesn’t run all the time. Right now I have two small rod ovens that run all the time as it is. I only have a few pounds of 7018 open at the moment and I have a job to get done that should use most of that. If the situation arises, I may leave them unplugged to see the difference in the Bill before I fire up the big one. Having the large oven will make it much more affordable to buy electrodes.
          I guess the operating cost will depend on how well insulated the rod ovens are. The high initial cost of a large rod oven has discouraged me from purchasing one up to now.
          -Don
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
