Camera Mount
  • Camera Mount
    This project was to build a mount for a forward-facing camera for a power boat. The camera mount will attach to the top of the roof of the cockpit. The channel detail will be mounted to the top of the roof of the cockpit and will support the cables that go to the camera. The purpose of the camera is to provide excellent forward visibility even when the boat occupants are in sub-optimal locations. The first picture shows my friend and customer Ray holding the completed camera mount. It is ready for powder coating.
    1. Camera Mount
    Click image for larger version  Name:	1. Camera Mount.jpg Views:	5 Size:	91.9 KB ID:	614934
    This was mostly a machining project, but I did have one weldment. Unfortunately, the weld maxed out my Miller Dynasty 200 DX welder. The foot was ¾” x 1” x 4” Aluminum and the channel was 1/8” x 1” x 2”. I used the following parameters for the TIG weld:
    A/C Current output: 200 amps.
    Balance: 70% Electrode Negative
    Frequency: 50 Hz
    Electrode: 3/32” Tri Mix from Arc Zone.
    Shielding Gas: 75% Argon 25% He
    Shielding flow rate: 15 CFH
    Below is picture of one weld and a second picture of the entire 8’ weldment:
    2. Foot welded on
    Click image for larger version  Name:	2. Foot welded on.jpg Views:	5 Size:	129.7 KB ID:	614935
    3. Entire channel
    Click image for larger version  Name:	3. Entire channel.jpg Views:	5 Size:	65.8 KB ID:	614936
    The next picture shows the access cover removed to gain access to the cable.
    4. Access cover removed
    Click image for larger version  Name:	4.  Access cover removed.jpg Views:	5 Size:	104.0 KB ID:	614937
    And here is the access cover installed.
    5. Access cover installed
    Click image for larger version  Name:	5. Access cover installed.jpg Views:	5 Size:	106.7 KB ID:	614938
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    This is a picture of the camera mount all done.
    6. Camera mount done
    Click image for larger version  Name:	6. Camera mount done.jpg Views:	20 Size:	86.1 KB ID:	614940
    I used my Bridgeport for most of the work, but I used a router table to make the radii on all of the parts:
    7. Router table setup
    Click image for larger version  Name:	7. Router table setup.jpg Views:	20 Size:	139.6 KB ID:	614941
    Here is a view from the camera. (As you can see the boat is still in its winter storage.)
    8. The cameras view
    Click image for larger version  Name:	8. The cameras view.jpg Views:	20 Size:	120.5 KB ID:	614942
    Here is a front view of the boat. The camera mount will be installed on the top of the roof of the cockpit.
    9. Front view of boat
    Click image for larger version  Name:	9. Front view of boat.jpg Views:	18 Size:	65.7 KB ID:	614943
    Last but not least here is a side view of the boat for perspective.
    10. Side view of boat
    Click image for larger version  Name:	10. Side view of boat.jpg Views:	18 Size:	132.7 KB ID:	614944
    -Don
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Nice boat too!
        Very Nice...........Salt or Fresh water there?
          We are on the Great Lakes so it is fresh water.
          -Don
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            Yeah, I was just curious if the end user was going to plate or paint any of that aluminum for corrosion? Out here even though were 40 miles in from the Pacific , the aluminum corrodes relativity fast without plating or powder coating....and when I do some stuff for my buddies on there boats I push stainless even though its a pain to work with it seems to hold up better in most conditions once polished.
            Carry on as I enjoy the Fab and machine work as much as the welding...
              Ray is planning on white powder coating the camera mount parts. I have done other projects for Ray and he specifies a lot of stainless steel. Here are two stainless steel parts that I made for him in the past. Bulk head fittings:
              Miller Thunderbolt
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                And here is a coupler
                Miller Thunderbolt
                Lincoln LE 31 MP
                Lincoln 210 MP
                16" DuAll Saw
                15" Drill Press
                20 Ton Arbor Press
                Bridgeport
                  Ray has a pretty nice ride there.......how's it powered? and what about 32-35' ft?
                    Ray's boat is 43 feet long if you don't count the front sprig or the rear swim platform.
                    Here is a picture of the boat with his normal sized daughter standing in front of it.
                    The back of the boat is slightly cut off, but you get the idea of size.
                    It is powered by two diesel engines. Here is a pictures of the two engines.
                    Click image for larger version  Name:	IMG_7847 (1).jpg Views:	5 Size:	138.2 KB ID:	615007
                    The inside of the engine compartment is covered with about 4" of insulation to deaden the sound.
                    -Don
                    Miller Thunderbolt
                    Lincoln LE 31 MP
                    Lincoln 210 MP
                    16" DuAll Saw
                    15" Drill Press
                    20 Ton Arbor Press
                    Bridgeport
                      Here are three pictures of the powder coated parts.
ID:	615012 Click image for larger version
                      Miller Thunderbolt
                      Lincoln LE 31 MP
                      Lincoln 210 MP
                      16" DuAll Saw
                      15" Drill Press
                      20 Ton Arbor Press
                      Bridgeport
                        Nice and looks as if he stores that inside at some point?
                        A family member used to captain this luxury 82' fishing vessel, which now operates in the Indian ocean...built in 2014 at Weaver in Maryland , he watched it from laying the keel , Click image for larger version
ID:	615015 Click image for larger version
ID:	615016 Click image for larger version
ID:	615017 Click image for larger version
                        through sea trials to loading it on a freighter bound for the Seychelles islands. .....Amazing fast elegant fishing vessel powered by 2 German 16 cy power plants.......he no longer works for him and is now fishing in South America.
                          Ray lives on the west side of the upper peninsula of Michigan. The winters up there are extreme with a lot of snow. Ray keeps the boat in inside storage at a marina in the winter. It is currently still in storage.
                          -Don
                          Miller Thunderbolt
                          Lincoln LE 31 MP
                          Lincoln 210 MP
                          16" DuAll Saw
                          15" Drill Press
                          20 Ton Arbor Press
                          Bridgeport
                            I used to have a flat bottom aluminum Jon boat. That sucker had to be at least 10’ long. Powered her with a paddle and a 12v trolling motor, but it was a big paddle you see. Called her the B-*** Kicker. Kept me out of trouble all through high school.
