Tig Brazed Helmet Hook Kit.
  • tarry99
    And while were on the Silicon Bronze subject of which I've used allot ..........I just ran across this :ERCuAl-A2 Aluminum Bronze A2 Copper TIG welding wire..........that is great for welding cast iron..on AC Tig
    with a little preheat..
  • ryanjones2150
    Nice job Don.
    That tig brazing is fast too. When I built the belt guard for my compressor, I tacked it together with er70-s2 and then tig brazed it out with silicon bronze. My plan was to lessen the distortion so it stayed straight and looked nice. Not only did I zip through that job, at the end, had zero distortion. And as the part heats up it goes even faster.
    I wish I was as patient with the picture taking as you are. You always do an excellent job of documenting your work.
  • MAC702
    Clever use of otherwise wasted space. Thanks for the pictorial!
  • Don52
    Originally posted by smawgmaw View Post
    Nice job!
    Thanks, it gave me the opportunity to TIG braze using Silicon Bronze. It is a good application for TIG brazing, because the plasma cut parts pretty much held themselves together, so there is very little demand on the braze joint.
    -Don
  • smawgmaw
    Nice job!
  • Don52
    A few years ago, I purchased a selection of Silicon Bronze welding rods. I selected the 3/32” diameter rod.
    6. Silicon Bronze brazing rods
Name:	6. Silicon Bronze brazing rods.jpg
    In hindsight I might have been better off using the 1/16” rod, because I nipped the edge of the steel parts in some cases. Of course, once I got the feel for the Silicon Bronze rod, I was easily able to stay away from melting the steel edge even with the 3/32” rod, as you can see below.
    7. One joint brazed
Name:	7. One joint brazed.jpg
    And here the Helmet Hook is all done and mounted on my cylinder.
    8. All done
Name:	8. All done.jpg
    9. Mounted on cylinder
Name:	9. Mounted on cylinder.jpg
    Last but not least here is a picture of the helmet hook in use.
    10. Helmet hook in use
Name:	10. Helmet hook in use.jpg
    -Don
  • Don52
    started a topic Tig Brazed Helmet Hook Kit.
    A few years ago, I purchased a Hel-Hook Steel Welding Hanger Kit from Jody’s Weldmonger store. For the past 2-1/2 weeks I have been recovering from my Hernia operation, but I am getting stir crazy, so I decided to TIG braze the kit together. The kit comes with plasma cut steel parts that fit perfectly together, which are shown below.
    1. Helmet hook kit
Name:	1. Helmet hook kit.jpg
    Brazing works better if the parts are clean, so I sanded the edges of the parts that will be TIG brazed.
    2. Sanding side of U-piece
Name:	2. Sanding side of U-piece.jpg
    3. Sanding inside of U-piece
Name:	3. Sanding inside of U-piece.jpg
    5. Sanding edge of fingers
Name:	5. Sanding edge of fingers.jpg
