Tig Brazed Helmet Hook Kit.
  • Tig Brazed Helmet Hook Kit.
    A few years ago, I purchased a Hel-Hook Steel Welding Hanger Kit from Jody’s Weldmonger store. For the past 2-1/2 weeks I have been recovering from my Hernia operation, but I am getting stir crazy, so I decided to TIG braze the kit together. The kit comes with plasma cut steel parts that fit perfectly together, which are shown below.
    1. Helmet hook kit
Name:	1. Helmet hook kit.jpg
    Brazing works better if the parts are clean, so I sanded the edges of the parts that will be TIG brazed.
    2. Sanding side of U-piece
Name:	2. Sanding side of U-piece.jpg
    3. Sanding inside of U-piece
Name:	3. Sanding inside of U-piece.jpg
    5. Sanding edge of fingers
Name:	5. Sanding edge of fingers.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    A few years ago, I purchased a selection of Silicon Bronze welding rods. I selected the 3/32” diameter rod.
    6. Silicon Bronze brazing rods
Name:	6. Silicon Bronze brazing rods.jpg
    In hindsight I might have been better off using the 1/16” rod, because I nipped the edge of the steel parts in some cases. Of course, once I got the feel for the Silicon Bronze rod, I was easily able to stay away from melting the steel edge even with the 3/32” rod, as you can see below.
    7. One joint brazed
Name:	7. One joint brazed.jpg
    And here the Helmet Hook is all done and mounted on my cylinder.
    8. All done
Name:	8. All done.jpg
    9. Mounted on cylinder
Name:	9. Mounted on cylinder.jpg
    Last but not least here is a picture of the helmet hook in use.
    10. Helmet hook in use
Name:	10. Helmet hook in use.jpg
    -Don
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Nice job!
      A FEW OF MY TOYS !!!
      MX Linux
      LinuxMint
      Miller Roughneck 2E
      Lincoln Weldpak 100
      Gianttech Arc 200
        Originally posted by smawgmaw View Post
        Nice job!
        Thanks, it gave me the opportunity to TIG braze using Silicon Bronze. It is a good application for TIG brazing, because the plasma cut parts pretty much held themselves together, so there is very little demand on the braze joint.
        -Don
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DoAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Clever use of otherwise wasted space. Thanks for the pictorial!
            Nice job Don.
            That tig brazing is fast too. When I built the belt guard for my compressor, I tacked it together with er70-s2 and then tig brazed it out with silicon bronze. My plan was to lessen the distortion so it stayed straight and looked nice. Not only did I zip through that job, at the end, had zero distortion. And as the part heats up it goes even faster.
            I wish I was as patient with the picture taking as you are. You always do an excellent job of documenting your work.
              And while were on the Silicon Bronze subject of which I've used allot ..........I just ran across this :ERCuAl-A2 Aluminum Bronze A2 Copper TIG welding wire..........that is great for welding cast iron..on AC Tig
              with a little preheat..
