Ray my customer and friend sent me a drawing and a solid model of the fishing rod holder that he wanted me to machine and weld for him. He also sent me all of the required stock. He designed it on AutoCAD inventor so I pulled the solid model in the STEP format into SolidWorks, so that I could use it.
1. SolidWorks Model of Rod Holder
If I were still working, I would have printed the part full size on our $50,000 roll plotter at work, but I retired in the end of June, so I laid it out full size on piece of paper that I cut from a paper bag. (How far we fall.) I used my Fireball squares to line up the end plates and I rested each end of the tube on a 1” magnetic block also from Fireball Tool Company to hold it off the table. I held the tube in place with two 2” x 2” x 1” magnetic blocks pressed against the side of the tubes on each end.
2. Magnetic blocks to hold parts in place
If you look closely in the following picture you can see my layout pencil lines.
3. Close up of blocks
Next, I positioned all of the parts in the fixture.
4. Holding pieces in place
In this picture you can see how the 1” block holds the tube off the table and how the 2” blocks hold the tube in place sideways.
5. Close up of magnetic blocks
