Basket Repair Project.
  • Basket Repair Project.
    My customer and former associate Jason asked me to help him to repair a wire frame basket. I say former because we both retired from the same company in the last six months. Jason attempted to repair the by epoxy gluing it back together. Before too long the epoxy cracked at the joint. It was a case of man against hardware and hardware was winning. Jason wanted some help to win the battle. I guess you could say that it got personal. Below are two pictures of the basket with the epoxy.
    1. Basket with epoxy
Name:	1. Basket with epoxy.jpg
ID:	612456 2. Close up of epoxy joint
Name:	2. Close up of epoxy joint.jpg
    The first step was to remove the epoxy so that I could weld it.
    3. Chiseling the epoxy off
Name:	3. Chiseling the epoxy off.jpg
    4. Epoxy removed
Name:	4. Epoxy removed.jpg
    The next step was to sand and power wire brush off the paint. I found that the power wire brush worked better.
    5. Sanding off paint
Name:	5. Sanding off paint.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Now I could finally weld it. I chose the oxyacetylene process, because I believe that the extra heat of this process tends to boil off impurities. I cleaned it a reasonable amount, but there was still paint near the wires of the basket that was difficult to remove.
    6. Welded joint
Name:	6. Welded joint.jpg
    7. Several Welded joints
Name:	7. Several Welded joints.jpg
    This is a mockup of my setup that I found worked best. I placed the backup bar about 1/16” from the 1/8” bar to prevent it from sucking too much heat from the bar. The wire of the basket was resting on the heat sink bar to help keep it cool. The challenge was heating up the 1/8” bar without vaporizing the wire.
    8. Backup bar and weight
Name:	8. Backup bar and weight.jpg
    The welding process burned up some of the existing paint, so I wire brushed it down to bare metal
    9. Basket all welded
Name:	9. Basket all welded.jpg
    To keep it simple I only painted the top of the basket, so I masked the rest.
    10. Masked for painting
Name:	10. Masked for painting.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Here is a close up and a view of the entire painted basket.
      11 Joints painted
      Click image for larger version  Name:	11 Joints painted.jpg Views:	0 Size:	41.8 KB ID:	612468
      12. Basket all done
      Click image for larger version  Name:	12. Basket all done.jpg Views:	0 Size:	152.9 KB ID:	612469
      -Don
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Kind of an odd thing to repair, Don. Is it sentimental wire basket or a one of a kind item?
          I think that it perfectly met Jason’s requirements and it became a challenge or even an obsession for Jason to get it fixed. Jason obviously felt that it was worthwhile spending time applying the epoxy. I also believe that my welds will be a lot stronger than the original spot welds, which nicked the wires.
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            I have no doubt. That epoxy is about the worst thing to try and get off to weld. Good choice in using O&A.
