Small backhoe cylinder repair
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14Tags: None
- 1 like
Originally posted by ryanjones2150 View PostAlmost looks a bit undersized for the main boom cylinder, but I guess there has to be a breaking point somewhere, may as well make it easy to get to!
Took me awhile to realize why the bolts and pins were all US vs metric like on the tractor. Then the light went off in my head, aftermarket made by Woods.
I'm guilty also. "It'll be fine because there is a safety factor engineered in, right?"MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
I am looking forward to pictures of your repair.
-DonMiller Thunderbolt
Smith Oxyacetylene Torch
Miller Dynasty 200DX
Lincoln SP-250 MIG Welder
Lincoln LE 31 MP
Lincoln 210 MP
Clausing/Colchester 15" Lathe
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
Well this job is done. Not the way I planned. Picked up new cylinder end, cut off old and welded it on, simple. Not so fast. Machinist made it out of a pc of 4140 or something similar. I didn't think anything of it. Welded it on, slip pin in to check that it is still straight, pin seized, pressing it out the new pc split. Not happy. Cut off again, took a pc of 1-1/2" hot rolled and drilled it on my drill press and welded it on. Should of done that in thw first place. Moral is don't put pin in while still hot, I knew better. But then maybe this would of broke in service anyway.
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
- 1 like
To line it up I extended the cylinder to keep heat away from seals. Inserted bar stock into both ends and measured between them. Also used a square to check to rod. Tacked it while checking. When I was comfortable it was tacked good I welded it out with tig, let cool, run drill through again and used die grinder as needed to get pin to slide through nicely. Drilled and tapped grease fitting last on the second pc. New pin I made is 4140 hardened.
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
I like your set up for keeping everything straight. I always enjoy following your posts. I am not familiar with the process for welding rod eyes on cylinders. Do you think mild steel will be strong enough for the rod eye?
Lincoln LE 31 MP
Lincoln 210 MP
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
