Swiss Bar/Multi-Grip Bar homemade
  • Swiss Bar/Multi-Grip Bar homemade
    https://www.garage-gyms.com/multi-gr...swiss-barbell/
    I would like to make this gym tool similar to a dumbbell barbell, I think it is called swis bar or similar, could you help me thanks how do I proceed? '
    You have the measurements. Cut the parts and weld it up. Simple...Bob
      One idea that comes from the example in the article you linked is to use square tubing for the outside parallels. This will be a much easier joint to fabricate and weld than a round tube welded perpendicularly to another round tube.
        Looks like the perimeter frame is 1.5" square tube...the grips are either knurled or have some form of rubber coating?.........take a look at the brochure..
          I would like to make a solder mask with a wooden panel to have the references.
          https://youtu.be/aCTU6G-eVnw
