This came in today to straighten. 35" dia x 1/4" thick. One of two on the mower. Looks like fun. Tall grass and weeds with a hidden stump, snapped it clean off. New one is $900 from John Deere. Probably won't get to it for awhile but I'll follow up. I think most of the damage was after this shaft broke the other disc beat on it.
Bent brush hog disc
Bent brush hog disc
MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14Tags: None
- Likes 1
Been raining all week so catching up on shop work. First remove blades and shaft stub. The pc of shaft was stubborn. Took a few heating sessions. Next get the blade holder straight. Then start on the pan. Sliced it in two spots to make it easier to straighten. Was tougher than I thought but it's plenty good enough. Last pic is the final heating session to remove any stress.
MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
- Likes 1
- Likes 1
MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
- Likes 1
First I was mistaken on pan thickness, it is 3/16". Next customer told me a new disc/blade holder from John Deere costs $900. I took a quick look on the interenet for one, used or after market and came up with nothing. I figured about 4 hours to do this, so I am below the 50% mark that is kind of my benchmark for repair or replace on things like this that probably won't come out like new or close to it. Didn't plan on 3/4 hour to remove the old shaft or 20 minutes to straighten one blade. Straightening just took a little bit longer. This is the only pc. the customer dropped off, he is going to get a new shaft and replace it himself, hope he can. No shear pin on the parts I have. Lastly the finished picture looks better than it really came out however it should be fully functional.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
- Likes 1
In retrospect since about 1/2 of the blade holder welds were cracked already I should of just cut it off and straightened it and the pan seperately, then welded them back together at the end. They kind of fought against each other while straightening plus then I could of straightened the blade holder in the press vs using heat.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
- Likes 1
The shear pins are usually at the gear box PTO shaft .
It sounds like he had used wrong grade bolt for shear pin.
My JD brush hog has two swinging blades. I replaced them a few years ago and are 1/2" thick.
Depending on bend damage, I would be concerned about balance and vibration. The blades on mine spin at 160 MPH according to manual.
I thought about balance vibration issues. Made sure the blade holder was even at both ends relative to center hub. Also since I didn't really add or subtract any material from the pan it should be ok plus the pan od is pretty equal to the center hub with small variations. The mower is I think 10 foot? It has two discs. Hopefully the other one is undamaged as I did not see it but I will make sure he checks it. I've seen a few of these that are being used in much worse shape than this one when I finished it so I assume it will be fine.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
- Likes 1
