Muffler Replacement
  • Muffler Replacement
    The baffles on the muffler on my friend Rick’s tractor were shot, so it was very noisy. The original muffler had been welded to the exhaust pipe, so I cut through the weld of the old worn out muffler and welded on a new one. I like to weld the muffler to the pipe or a Nipple, because the threads of the muffler are in thin sheet metal and they crack off as shown in the following link.
    https://forum.millerwelds.com/forum/...ohn#post598219
    The first picture shows where I cut through the original weld. The weld looked like bird $hit, but it held up until the muffler wore out so I can’t complain.
    1. Old Muffler
    Click image for larger version  Name:	1. Old Muffler.jpg Views:	0 Size:	100.5 KB ID:	610932
    The new muffler had a 1” NPT thread on it and the pipe was ¾” nominal pipe size, so I screwed in a 1” NPT close nipple into the muffler to reduce the hole size as shown below.
    2. Muffler with nipple
    Next I sawed off the nipple with about 1/16” protruding as shown below.
    3. Muffler with cut down nipple
    Click image for larger version  Name:	3. Muffler with cut down nipple.jpg Views:	0 Size:	35.5 KB ID:	610934
    Unfortunately, I didn’t take a picture of the weld, but I welded the nipple to the muffler. Then I welded the muffler to the exhaust pipe as shown below.
    4. Muffler welded to pipe
    Click image for larger version  Name:	4. Muffler welded to pipe.jpg Views:	0 Size:	97.9 KB ID:	610935
    Last but not least I painted it. I didn’t bother to purchase high temperature paint so it will burn off the hot exhaust pipe, but the paint should still protect the muffler.
    5. Muffler painted
    Click image for larger version  Name:	5. Muffler painted.jpg Views:	0 Size:	76.5 KB ID:	610936
    -Don
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Looks almost identical to the previous one minus the nipple you welded on.
    I need that fancy animation thing you’re using there too.
      Tried to send a PM to ya Don, but I don’t think it worked. I keep getting an error message that makes no sense....like a woman, if you don’t know whats wrong I’m not going to tell you...that kind of message.
        I will PM you when I get back from my bicycle ride. I am at my turn around point of my 25 mile ride on the Macomb Orchard Trail in Armada MI. This is what I can see from the bench that I am sitting on.
Name:
        -Don
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DoAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Testing
            Testing
              Here is a picture of the muffler installed in the tractor.
              -Don
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DoAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
