Aluminum Gate Installation
  • Metjunkie
    Don, you're quite the welder/artist. I'll just call you a weldist! Beautiful gate, beautiful house! Well done.
  • Don52
    Here is a picture of the mounted closed gate from the street.
    21. Gate closed
Name:	21. Gate closed.jpg
    Last but not least here is a picture of the opened gate, looking towards the street.
    22. Gate opened
Name:	22. Gate opened.jpg
    -Don
  • Don52
    Last Saturday we installed the gate. Here is a close up picture of the hinge block and the pintle. After some experimenting we found that it was easiest to mount the top block to the gate leaf, then hang the gate and then slide the lower bearing block onto the lower pintle and finally mount the lower bearing block to the gate.
    16. Upper bearing block mounted on pintle
Name:	16. Upper bearing block mounted on pintle.jpg
    Here is a picture of the gate bracket bolted to the gate.
    17. Gate bracket mounted
Name:	17. Gate bracket mounted.jpg
    Here is a close up of my two pass stainless steel TIG weld, which attaches the pier bracket to the plate in the pier.
    19. Pier bracket welded to plate in pier
Name:	19. Pier bracket welded to plate in pier.jpg
    The following picture shows the linear actuator temporarily mounted to the newly welded pier bracket.
    20. Linear actuator mounted
Name:	20. Linear actuator mounted.jpg
  • Don52
    11. Gate leaf welded
    Click image for larger version  Name:	11. Gate leaf welded.jpg Views:	0 Size:	75.9 KB ID:	610528
    I found that the pivot pin of the gate actuator wouldn't fit in the bore of the gate bracket because of the powder coat, so I brought home the gate brackets and reamed them with an adjustable reamer.
    12. Reaming off powder coat from bore
    Click image for larger version  Name:	12. Reaming off powder coat from bore.jpg Views:	0 Size:	89.2 KB ID:	610529
    13. Testing pivot pin in reamed hole
    Click image for larger version  Name:	13. Testing pivot pin in reamed hole.jpg Views:	0 Size:	54.7 KB ID:	610530
    14. Reamer has just paint on it no Aluminum
    Click image for larger version  Name:	14. Reamer has just paint on it no Aluminum.jpg Views:	0 Size:	138.4 KB ID:	610531
    The pier bracket had to be welded by me in the field and there was only 8" between the bracket and the ground, so I decided to chamfer the top so that I could weld it with two passes from the top instead of all the way around as specified. I also have only limited experience welding overhead with a mirror.
    15. Chamfered pier bracket
    Click image for larger version  Name:	15. Chamfered pier bracket.jpg Views:	0 Size:	114.6 KB ID:	610532
  • Don52
    The next step was to do a dry run with all of the details to insure that we had all of the proper hardware and everything fit.
    6. Checking fit and our measurements
Name:	6. Checking fit and our measurements.jpg
    The first thing that we found is that the pintles bottomed out by hitting concrete before they were in the correct position, so I brought the pintles home and cut 1" off the end.
    7. Cutting down the pintles
Name:	7. Cutting down the pintles.jpg
    8. Pintles cut down
Name:	8. Pintles cut down.jpg
    This is a welding forum, so here are three pictures that the fabrication vender sent to me.
    9. Gate leaf weld
Name:	9. Gate leaf weld.jpg
    10. Leaf welded
Name:	10. Leaf welded.jpg
  • Don52
    started a topic Aluminum Gate Installation
    Last fall I prepared detailed drawings for the driveway gate for my friend Scott, who is an engineer that I work with. Scott had previously designed the piers and arranged their construction. The piers are actually an armature of stainless steel, which goes about five feet deep into a footing. The bricks of the pier rest on the footing and are built up around the armature. The first picture shows my SolidWorks design of the gate assembly.
    1. Gate Assembly
Name:	1. Gate Assembly.JPG
    The second picture shows the gate leaf components.
    2. Gate leaf asm
Name:	2. Gate leaf asm.jpg
    The third picture shows the weld callouts for the gate leaf. The gate consists of 2" x 4" Aluminum tubing as well as three solid bocks that have tapped holes in them. The curved tube is bent the hard way and we couldn't find anyone willing and able to bend the tube in the Detroit area, so we had a company in
    Chicago bend it for us. I sent the design out to one of my company's local fabrication venders for welding, because I was concerned that the job was a little big for me and that my Dynasty 200 DX welder wouldn't have enough power to weld the heavy blocks, even with a Helium Argon mix.
    3. Gate leaf weld callouts
Name:	3. Gate leaf weld callouts.jpg
    I chose to use spherical bearings for the hinge bearings so that the bearings wouldn't fight each other if the pintles weren't perfectly aligned. I used a thrust bearing that had a concave recess that matched the diameter of the ball, so the thrust bearing would also accommodate misalignment.
    4. Spherical bearing and thrust washer
Name:	4. Spherical bearing and thrust washer.JPEG
    The pintles are 1" stainless steel with 1"-8 UNC threads on them. My design called for the pintles to be reverse bored as shown below to add a proper finish and to make the bearings fit in the blocks that had to mount to the 4" wide tubing.
    5. Spherical and thrust bearing
Name:	5. Spherical and thrust bearing.jpg
