Commercial Tree Stand Repair
  • Commercial Tree Stand Repair
    I didn't realize that a commercial Christmas tree stand could cost $472. Figure 1 below shows a typical one.
    1. Commercial Tree Stand
Name:	1. Commercial Tree Stand.jpg
    One of the engineers that I work with dropped off an heavy duty Christmas tree stand to be repaired. Originally it had 4x 1/2"-13 UNC PEM type nuts pressed into tabs that held screws that contacted the tree as shown below. Two of the four PEM nuts had pulled out.
    2. Broken Tree Stand
Name:	2. Broken Tree Stand.jpg
    3. PEM Threaded insert
Name:	3. PEM Threaded insert.jpg
    My friend had replaced the missing PEM nut with two nuts as shown below.
    4. Nut to replace missing insert
Name:	4. Nut to replace missing insert.jpg
    The tab that supported the PEM nut was kind of wimpy as shown below.
    5. Not much metal on tab
Name:	5. Not much metal on tab.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Some of the tabs were bent right at the hole instead of the base of the tab.
    6. Bent tab
Name:	6. Bent tab.jpg
    The other problem was that the base of spike that supported the tree was cracked where it was attached to the water pan.
    7. Crack at base of spike
Name:	7. Crack at base of spike.jpg
    After I removed the spike from the pan, I found that there was a cold lap joint on the weld that attached the spike to the pan. The rusty metal in the next two pictures show that there was large areas of the weld with no penetration.
    8. Cold lap on weld-1
Name:	8. Cold lap on weld-1.jpg
    9. Cold lap on Weld-2
Name:	9. Cold lap on Weld-2.jpg
    This defective weld also minimized the foot print supporting the spike, The minimum foot print in conjunction with the damaged PEM nuts caused a moment on the base of the spike that cracked the bottom of the pan as shown below. This is a problem because it would cause the tree water to leak out of the pan.
    10. Bottom of stand
Name:	10. Bottom of stand.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      11. Crack on bottom near spike
      Click image for larger version  Name:	11. Crack on bottom near spike.jpg Views:	59 Size:	62.7 KB ID:	608653
      I cut out a disk to beef up the area where the spike attaches to the pan.
      12. Cutting disk
      Click image for larger version  Name:	12. Cutting disk.jpg Views:	55 Size:	104.1 KB ID:	608654
      13. Disk cut
      Click image for larger version  Name:	13. Disk cut.jpg Views:	54 Size:	142.8 KB ID:	608655
      I TIG plug welded the spike to the disk as shown below and then fillet welded the top of the spike to the disk on the other side (not shown in this picture)
      14. Spike plug welded
      Click image for larger version  Name:	14. Spike plug welded.jpg Views:	54 Size:	121.7 KB ID:	608656
      Next I MIG welded the spike/disk assembly to the bottom of the pan as shown below.
      15. Spike replaced-1
      Click image for larger version  Name:	15. Spike replaced-1.jpg Views:	55 Size:	59.5 KB ID:	608657
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Nice, Gotta love Jacobs Rubber flex collets...Bob
          16. Spike replaced-2
          Click image for larger version  Name:	16. Spike replaced-2.jpg Views:	56 Size:	69.9 KB ID:	608660
          I also TIG welded the spike to the bottom of the original pan.
          17. Spike welded to top-1
          Click image for larger version  Name:	17. Spike welded to top-1.jpg Views:	53 Size:	66.5 KB ID:	608661
          18. Spike welded to top-2
          Click image for larger version  Name:	18. Spike welded to top-2.jpg Views:	51 Size:	80.6 KB ID:	608662
          I decided to remove the wimpy tabs and replace them with thicker wider tabs. Notice the fill-in weld shown in the upper left hand view. (You have to work with the geometry that you are dealt.)
          19. SolidWorks drawing of new tab
          Click image for larger version  Name:	19. SolidWorks drawing of new tab.jpg Views:	53 Size:	66.7 KB ID:	608663
          I tap drilled the tabs for 1/2"-13 UNC threads. I wanted to orient the flats of the nut parallel to the chamfer so I made a threaded arbor to align the tap drilled hole in the tab with the threaded hole in the nut.
          20. Nut alignment arbor
          Click image for larger version  Name:	20. Nut alignment arbor.jpg Views:	53 Size:	187.8 KB ID:	608664
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            Next I TIG welded the nut to the tab.
            21. Nut in place for welding
Name:	21. Nut in place for welding.jpg
            22. Nut TIG welded
Name:	22. Nut TIG welded.jpg
            Then I ran a 1/2"-13 UNC tap thru the nut and tapped the tab as shown below.
            23. Tab tapped
Name:	23. Tab tapped.jpg
            24. Tab - nut asm done
Name:	24. Tab - nut asm done.jpg
            Next I cut off the four tabs.
            25. Old tab cut off
Name:	25. Old tab cut off.jpg
            Miller Thunderbolt
            Lincoln LE 31 MP
            Lincoln 210 MP
            16" DuAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              Then I clamped the new tab/nut assembly in place.
              26. New tab clamped in place
Name:	26. New tab clamped in place.jpg
              Finally I TIG welded the tabs to the base.
              27. Weld on bottom of brace
Name:	27. Weld on bottom of brace.jpg
              28. Top weld on tab
Name:	28. Top weld on tab.jpg
              29. Bottom Weld on tab
Name:	29. Bottom Weld on tab.jpg
              And here it is all done except for painting.
              30. Tabs all welded
Name:	30. Tabs all welded.jpg
              Miller Thunderbolt
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                Last but not least I painted it.
                31.Bottom Painted
Name:	31.Bottom Painted.jpg
                32. Top Painted
Name:	32. Top Painted.jpg
                33. All Done
Name:	33. All Done.jpg
                -Don
                Miller Thunderbolt
                Lincoln LE 31 MP
                Lincoln 210 MP
                16" DuAll Saw
                15" Drill Press
                20 Ton Arbor Press
                Bridgeport
                  Now it’s a $1000 tree stand. Good work, Don.
                    Don, I bet they could use that for the tree at Rockefeller center. Another job well done.
                      Yes, I like the Jacobs Rubber flex collets. They make my 15” lathe behave like a small lathe.
                      -Don
                      Miller Thunderbolt
                      Lincoln LE 31 MP
                      Lincoln 210 MP
                      16" DuAll Saw
                      15" Drill Press
                      20 Ton Arbor Press
                      Bridgeport
                        Nice! I always love the final stages of repainting a project and making it look new again. Great job
                        Millermatic 252, Hypertherm Powermax30 XP, Hypertherm Powermax45 XP, LOTOS LTP5000D https://fabricationguy.com/
