Adding Casters to Welding Table
  • Adding Casters to Welding Table
    I found that I wasn't using my welding table too often because it was up against the wall and large weldments couldn't overhand the table due to the wall. The empty table weights about 400 lbs and I was storing metal on the bottom shelf so it made it even heavier. The bottom line is that the table was so difficult to move that I never moved it. My solution was to modify the table to add casters and leveling feet. The first picture shows the original table before modifications.
    1. Original welding table
    Click image for larger version  Name:	1. Original welding table.jpg Views:	2 Size:	129.5 KB ID:	607985
    My shop has three rooms in it and I wanted the welding table to fit through the doorways that connected the rooms of the shop. My addition is one of the rooms has a floor that is 11 inches higher than the adjacent room and I have a ramp to allow me to push welders and other equipment from one room to the other. I went through a bunch of concepts that allowed the table to fit through doorways and to make it up the ramp without bottoming out. I also wanted the casters and leveling feet to be wide enough to be stable.
    2. SolidWorks Model of modified welding table
    Click image for larger version  Name:	2. SolidWorks Model of modified welding table.jpg Views:	2 Size:	51.4 KB ID:	607986
    2.1 Swivel Caster
    Click image for larger version  Name:	2.1 Swivel Caster.jpg Views:	2 Size:	38.9 KB ID:	607987
    2.2 Weld Table Fixed Caster
    Click image for larger version  Name:	2.2 Weld Table Fixed Caster.jpg Views:	2 Size:	39.0 KB ID:	607988
    2.3 Weld Table Swivel Caster on Ramp
    Click image for larger version  Name:	2.3 Weld Table Swivel Caster on Ramp.jpg Views:	2 Size:	36.2 KB ID:	607989
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    The first step was make all of the components as shown in the following picture. I ordered the 1" x 3" x 24 " bar, which is shown on the right, from On Line Metals. I used this bar to make the new thicker feet .
    3. Parts done except feet
Name:	3. Parts done except feet .jpg
    4. Cutting feet
Name:	4. Cutting feet.jpg
    4.1 Chamfering edge of foot
Name:	4.1. Chamfering edge of foot.jpg
    The bottom of the bar had mill scale on it, so I used my Strong Hand Tools Grasshopper to ground the part.
    5. Using Grasshopper to ground part
Name:	5. Using Grasshopper to ground part.jpg
    5.1 Caster mounting plate welded
Name:	5.1 Caster mounting plate welded.jpg
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      6. Welding caster mounting plate to tubular strut
Name:	6. Welding caster mounting plate to tubular strut.jpg
      7. Caster mount plates welded
Name:	7. Caster mount plates welded.jpg
      The table weighs about 400 lbs so I cribbed it up by jacking up each side and adding boards under the feet on each end.
      8. cribbing up table
Name:	8. cribbing up table.jpg
      I have a Z-Lift table, so I used it to jack it up the rest of the way.
      9. Lifting table
Name:	9. Lifting table.jpg
      Once I the table was lifted, the first step was to cut off three inches from the bottom of the legs. This was necessary to prevent the leveling feet from bottoming out on the corner of the ramp.
      10. Leg ends cut off
Name:	10. Leg ends cut off .jpg
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DoAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        The next step was to weld the new thicker feet to the bottom of the legs. I used 1" thick metal for the feet to give good support for the 5/8-ll UNC threaded leveling feet, which I purchased from McMaster Carr.
        11. Feet in position for welding
Name:	11. Feet in position for welding.jpg
        To get adequate penetration for welding the 1" feet to the 1/8" tubing of the leg, I used my
        Lincoln 210 MP welder with dual shield flux core wire. The dual shield wire has a high arc density so it has outstanding penetration. I didn't require it in this case, but the slag allows this wire to be easily used in all positions.
        12. Welds on foot-1
Name:	12. Welds on foot-1.jpg
        13. Welds on foot-2
Name:	13. Welds on foot-2.jpg
        I used my Fireball Square to hold the struts in position for welding. (They are available from Fireball tool.)
        14. Fireball Square in position
Name:	14. Fireball Square in position.jpg
        15. Strut tack welded
Name:	15. Strut tack welded.jpg
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DoAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          16. Top and left weld on strut
Name:	16. Top and left weld on strut.jpg
          17. Right and overhead weld on strut
Name:	17. Right and overhead weld on strut.jpg
          18. Painted
Name:	18. Painted.jpg
          19. Casters and leveling feet mounted
Name:	19. Casters and leveling feet mounted.jpg
          20. Swivel caster
Name:	20. Swivel caster.jpg
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DoAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            21. Fixed caster
Name:	21. Fixed caster.jpg
            I tried it out and I was able to easily move the table between rooms of my shop and push the table up the ramp.
            -Don
            Lincoln LE 31 MP
            Lincoln 210 MP
            16" DoAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              Nice work Don, but then we've come to expect nothing less from you!
              Richard
              West coast of Florida
              Website
                Ya Don, good looking work. Thanks for posting all that.
                  I’ll take two sets of those, Don.
                    Thanks.
                    You are welcome.
                    You know it is funny, but my friend Rick at work gave me the set of casters that he recovered from the trash about seven years ago. The casters were from a skid that carries car bodies through the paint booth, so they had some paint on them, which I removed. The yellow tubes that I used for the struts, were obsolete parts from the scrap bin.
                    Lincoln LE 31 MP
                    Lincoln 210 MP
                    16" DoAll Saw
                    15" Drill Press
                    20 Ton Arbor Press
                    Bridgeport
