Adding material
  • Adding material
    Adding material to fit new parts.
    410L frame and slide. 309L added to the grip safety (it's a steel part and I know 309 and mild steel get along quite well, stainless won't take the black oxide but that part is hidden)
    Added a little material at a time. Let sit until cool to the touch and repeat.
    Low dollar item, so the gamble wasn't detrimental
    The hardest part was determining the base material initially. Then requested a smaple of 410L from Washington Alloy.
    This project that has continued over the past 7 years. Every now and then I decided to make another change.
    Better you than me shooting that firearm! That welding is ugly as all get out!
    A FEW OF MY TOYS !!!
    MX Linux
    LinuxMint
    Miller Roughneck 2E
    Lincoln Weldpak 100
    Gianttech Arc 200
      I won't take offense to that comment, its what I expect from the internet
        The material was added successfully...job done.
          Thanks for the writeup and pictorial! What new parts are you fitting? I'm just an armorer, no gunsmith, but love working on them.
            The first picture was for a low profile Novak rear and the second third and fourth are for a new grip safety
              Is this you, a keyboard warrior?
              https://www.facebook.com/3MinCrafts....5143954223457/
              MX Linux
              LinuxMint
              Miller Roughneck 2E
              Lincoln Weldpak 100
              Gianttech Arc 200
                yes sir
                that's me in the blue shorts
                  yes sir
                  I dont think so. I have seen the welds that you made and posted up for everyone to see!
                  MX Linux
                  LinuxMint
                  Miller Roughneck 2E
                  Lincoln Weldpak 100
                  Gianttech Arc 200
                    what I shared wasn't "welding"
                      I have no idea what they were saying in the video, but you put the smack down on that dude.
                      But may I suggest a side arm with a bit narrower of a grip for your tiny hands?
                        Yeah, I agree. It was more like trying to glue something to a firearm that should not be glued!
                        MX Linux
                        LinuxMint
                        Miller Roughneck 2E
                        Lincoln Weldpak 100
                        Gianttech Arc 200
                          smawgmaw You sound knowledgeable with the aesthetics of welding. Would you be willing to share what process and set-up you'd prepare to make a better appearing "weld"?
                            I get the purpose of the slide build up, but what’s the purpose of building up in the top of the beaver tail on the frame?
                              to create a proper transition from the frame horns to the GS
