Trellis Repair
  • Trellis Repair
    A coworker asked me to repair his wife's plant trellis, which had two broken legs as shown below.
    1. Trellis with broken legs
Name:	1. Trellis with broken legs.jpg
    When I inspected the broken weld on the leg, I noticed that the weld only penetrated about 1/3 of the way through the leg. In the following picture you can see the rusty cracked weld, which had minimal penetration.
    2. Rust on broken weld
Name:	2. Rust on broken weld.jpg
    First I removed the rust and paint from the legs in preparation for welding.
    3. Cleaned up legs
Name:	3. Cleaned up legs.jpg
    Next I cleaned up the joint as shown below.
    4. Cleaned up joint
Name:	4. Cleaned up joint.jpg
    I chose the oxyacetylene process for this application, because it is the most tolerant process for contamination. I cleaned as best that I could, but there was still some contamination in the joints that I couldn't easily get to. As you can see in the following picture the weld has a little contamination on the surface from the adjacent joints.
    5. Contamination on weld
Name:	5. Contamination on weld.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    To solve the problem, I just welded the adjacent joints to bubble out the impurities in them. In the following picture you can see that both the original and the adjacent welds are much cleaner. I also welded the remaining two legs, because they also had welds with minimal penetration as well.
    6. Cleaner weld
Name:	6. Cleaner weld.jpg
    The last step was to paint the trellis.
    7. All Done
Name:	7. All Done.jpg
    Sometimes the less used oxyacetylene process works best for an application like this.
    -Don
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Nice fix
        Ya Don, nice fix; and as always, great documentation.
