council building iron loft made at home
  • council building iron loft made at home
    hello I should make a loft 2 meters high 2.50 meters long 2, 30 meters some advice, as you would do with a little money thanks
    Scrap pipe or steel channels. How much capacity?
      sturdy lightweight, I do not have to load weights with a forklift or crane, such as a closet, one proportional to the surface
ID:	604961Click image for larger version
      file:///C:/Users/hp/Downloads/Catalogo%20Soppalchi%202018.pdf
        I know this is seemingly going to sound like an insult to engineers, but I think most are born with a degree of build something in them. Granted, not all equally of course, but to some degree, a bit in them.
        Looking at those pictures, as well taking or leaving the industrial look of metal construction, this like your other project is really about material type and what you do with it.
        Your circumstance will be the game changer in making that happen. Maybe your budget? It doesn't matter what we like more, it's what you want when it's done. Either you copy existing, modify from existing, or you get creative with materials readily available and watch your master piece grow.
          I would like to do it in tubes or in an empty metal box, a light structure like a platform with a raised platform on rigid uprights, what do you think, only that above there is little space around 1.50 meters, is it worth but? wide type leaning shelf Click image for larger version
ID:	605086Click image for larger version
ID:	605087Click image for larger version
            That 700 KG is 1500 lbs for us non metric guys. 2' black pipe should work for the legs and the platform or you can use 3" channel for the platform. Or wood 2x4's for the platform and 4x4 wood legs. Or another zillion options...Bob
              Eliminate the legs at the wall and lag that sill to the wall. That alone provides a huge improvement in structural integrity.
              Relocate the stairs to the face of the deck and make them pullup eliminating the stairs obstructing the doorway and gaining deck space along with more structural integrity by bolting a second sill to that wall.
              Weld tabs for the diaphragm braces direct to the legs and eliminate the clamp system that sticks beyond the deck and will either become an attempted hanger or a flesh ripper.
              PAD the braces to height of 7 feet above the floor with either styrofoam or several layers of carpet to minimize concussions.
              If this is supposedly moveable in the future frame deck corners with leg pockets of 2½" pipe at least 8" long with 2 setscrews to retain the legs.
              Chamfer feet of the legs to save tripping on them
              All diaphragm braces must go from leg to deck sill for maximum value.
              Without proper diaphragm bracing it's a parallelogram waiting to collapse.
              If possible at least 1 anchor should penetrate the foot and go 2" into the concrete.
                thanks for the precise suggestions, I enclose sketch drawing with measurements that I took today, Click image for larger version
ID:	605141Click image for larger version
                pralicamente the beam would be like amplitude between the supports 250 cm, height 190 cm, length 180 cm
                all in centimeters, as a material I would like to use box-shaped 100x 50 x 3 mm iron thickness both for the three riser columns and for the three 250 cm beams, what do you say on the one hand the housing on the brick wall 30 cm thick, from the Otherwise I hold up the uprights that bolt to the wall 18 centimeters thick and to the floor what you say. Is the roof 350 cm high from the ground? if you have other suggestions let me know, thanks for the sustenance
                https://www.oppo.it/tabelle/profilati-tubi-rettang.htm
                http://www.albaedile.it/prodotto/fer...50x3-mm-l-6-m/
ID:	605144Click image for larger version
                  Essentially you're building a pallet rack, but you're leaving out the vital diagonal component of the structure making it vulnerable.
                  Relying only on the welded joint is disaster waiting to happen.
                  Even minimal 1/8 x 1 strapping welded in as diagonals would increase the safety of the system by creating triangles.
                    you could kindly attach some drawings thanks. I have to figure out how to distribute the loads like unloading the weight evenly on the ground, otherwise everything collapses thanks
ID:	605206Click image for larger version
Name:	green-and-orange-storage-concepts-freestanding-shelving-units-ib42120-40108s-64_1000.jpg
                    https://www.homedepot.com/p/Storage-...108S/305650799
                    https://www.bunnings.com.au/steel-de...frame_p0910821
                      The purple elements are what you need to add.
                      They introduce triangles into the structure and triangles do NOT deflect unless the length of one leg changes.
                      The elements reduce stress on your existing joints and will prevent collapse.
                      They don't need to be heavy material.
                        diagonal reinforcement elements for building scaffolding or bridge tie rods. thank you sorry if I disturbed you. by eye a box-shaped 100x50x 3 mm how much could I load it, the whole floor as surface would be 4.5 square meters, what maximum load could it bear? thank you sorry if I disturbed you. Click image for larger version
Name:	orditura traverse.jpg
ID:	605231Click image for larger version
ID:	605232Click image for larger version
Name:	pallett rack mezzanino.jpg
                          Your load won't be distributed on the 4.5 sq meters, it will be on the total area of the 4 feet. The concrete floor will distribute the load some IF the concrete is reinforced.
                            I'm afraid it falls like a house of cards, maybe the lateral push demolishes the brick wall. prudence is never too much
ID:	605250Click image for larger version
ID:	605251Click image for larger version
                            the place is not bright we cannot make a virtual inspection of the images. thanks anyway for some valuable advice.
Name:	capannone 1 falda.jpg
Name:	larghezza locale interno.jpg
ID:	605255Click image for larger version
ID:	605256Click image for larger version
                              what do you think about it? how to make it more robust? thanks sorry if I insist thanks
